Axle retainer plate torque - JeepForum.com
post #1 of 6 Old 12-31-2010, 06:52 AM Thread Starter
olucier
anybody know the torque requirements for the 4 nuts that hold the axle retainer plate? 98 Shara Dana 44 rear axle
olucier is offline
post #2 of 6 Old 12-31-2010, 07:46 AM
robncar
robncar's Avatar
45 ft.-lbs., best practice is to use new nuts and bolts.
https://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 6 Old 12-31-2010, 07:59 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
X 2.
TheBoogieman is offline
post #4 of 6 Old 12-31-2010, 08:05 AM
Benderff
Benderff's Avatar
Grinding a corner off some grade 8 bolts is a lot better then trying to find them at the dealer. Stu's write-up has the exact info on the bolts.
Benderff is offline
post #5 of 6 Old 12-31-2010, 08:18 AM Thread Starter
olucier
Thanks everyone- new nuts, blue loctite. Old bolts though cleaned up
Replacing the rear bearings was a very easy job... I like working on Wranglers
olucier is offline
post #6 of 6 Old 12-31-2010, 10:59 AM
robncar
robncar's Avatar
X 2.
Kinda miss the old avatar(s)?
robncar is offline
D44 rear axle retainer plate bolts torque spec. Lud04X TJ Wrangler Technical Forum 14 10-26-2014 06:23 PM
what do i torque the backer plate to? (rear axle bearings) 03rubiconMG TJ Wrangler Technical Forum 3 05-18-2010 05:20 PM
MJ dana 44 axle retainer plates 93jeepyj YJ Wrangler Technical Forum 2 09-04-2009 01:00 PM
front bearing retainer plate missing shaft sleeve traumajunkey YJ Wrangler Technical Forum 1 03-21-2009 07:47 AM
axle retainer part number????? cincytj TJ Wrangler Technical Forum 8 02-18-2006 10:29 PM
