Axle broken?? - JeepForum.com
post #1 of 24 Old 05-10-2011, 09:49 PM Thread Starter
KidChronic
Axle broken??
Ok I'm new at this can you help me out? I went and did a little bit of rock crawling and I got a little excited and I tried this pile of rocks I saw. Anyways I got stuck in the middle and my friend went out to check it out when I tried getting out he noticed the right rear tire wasn't moving when I pushed the gas and it made a clicking noise so I stoped and had another jeep take me out! What was that clicking noise did I bream something? Plz help!!! Ty
KidChronic is offline
post #2 of 24 Old 05-10-2011, 09:52 PM
EricsGreen98Tj
Sounds like you broke the spider gears or mabey the ring and pinion gears. What axle do you have? If it was a D35 the broke shaft would have walked out of the housing....
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk https://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #3 of 24 Old 05-10-2011, 09:53 PM
EricsGreen98Tj
Do you have a traction aid? Locker, limited slip, posi......or is it open? Did you get your jeep home? If so pull the rear diff cover and take a look or a pic and post it...
post #4 of 24 Old 05-10-2011, 09:56 PM Thread Starter
KidChronic
I have d44 and it clicked a few times when it happened and yes I drove the jeep back home like there was nothing wrong with it but I'm worried something is wrong
post #5 of 24 Old 05-10-2011, 09:58 PM
EricsGreen98Tj
well you should pull the diff cover and look at your spider gears and your ring+pinion. Was you Tj hopping when you were on the throttle? Was there a loud SNAP!?
IDT a D44 is a c-clip axle so you may have broken a shaft but dont quote me on that....
B4 you pull the cover go buy some 80W-90 gear oil(2 quarts) and some RVT (The Right Stuff gasket maker is GREAT) so you have a way to put your diff back together to drive it if its your DD
post #6 of 24 Old 05-10-2011, 10:00 PM
EricsGreen98Tj
Was the other wheel still spinning?
post #7 of 24 Old 05-10-2011, 10:03 PM Thread Starter
KidChronic
I'll Take the diff cover off and have a look but no there was no loud snap. The tire had traction but it seemed like it didn't have enough power to take it out of bind. all the other tires had no traction.
post #8 of 24 Old 05-10-2011, 10:04 PM Thread Starter
KidChronic
Yes the other wheel was spinning
post #9 of 24 Old 05-10-2011, 10:10 PM
EricsGreen98Tj
Man if you have an Open diff only one wheel WILL spin. Suppose to work that way...
post #10 of 24 Old 05-10-2011, 10:11 PM
EricsGreen98Tj
Were you smoked out when this happend?? Mabey your just paranoid
post #11 of 24 Old 05-10-2011, 10:14 PM Thread Starter
KidChronic
Haha I hope so I was just wondering what that clicking noise was that it made
post #12 of 24 Old 05-10-2011, 10:15 PM Thread Starter
KidChronic
Sry I'm really new to this my last car was a geometro... Lol
post #13 of 24 Old 05-10-2011, 10:37 PM
EricsGreen98Tj
If your Tj came with the fractory Trac-lock the clutches that engage it can wear out(quickly btw) and make it malfunction; trying to decide which tire it wants to spin/give power to.
Have you got your factory build sheet yet? If you leave a message with Chrysler and give them your VIN # they will give you the list of options your jeep was built with. IF you knew what you had axle/diff wise it'd be alot easier to help you out.....
post #14 of 24 Old 05-10-2011, 10:38 PM
EricsGreen98Tj
Does your rear axle have a steel drain plug on the diff cover? or a rubber fill plug? Steel=Dana 44;rubber=Dana 35
post #15 of 24 Old 05-10-2011, 10:42 PM Thread Starter
KidChronic
Steel my jeep is a rubicon don't they have d44?
