AX15 to NV3550 swap questions - JeepForum.com
post #1 of 12 Old 11-25-2012, 11:13 AM Thread Starter
nbrege
nbrege's Avatar
2014 JK Wrangler
I need to repair or replace the AX15 in my '99 TJ. I have located a NV3550 from an '02 Wrangler X with 87K on it, the guy wants $300 obo for it. My question is if this is the best way to go. Is the NV a direct bolt-in replacement for the AX? Or is there any other mods that need to be done? I'm sure lots of people have done this before ... just looking for some advice/comments. Thanks...
2014 JK Willys, 3.6L, 6 speed, 3.73
nbrege is offline
post #2 of 12 Old 12-01-2012, 02:20 PM Thread Starter
nbrege
nbrege's Avatar
2014 JK Wrangler
Anyone?
nbrege is offline
post #3 of 12 Old 12-01-2012, 02:28 PM
Sandhara
is it the best way to go, 6 to 1 half dozen to another, it is technically stronger (slightly), but nv requires (in pretty sure) a special fluid that is more expensive than good old gear oil. Depending on the repairs that yours needs, it may also be a cheaper route (if the Nv is in good condition).
as far as i know it is a direct swap, i would really take a look at my trans mount and make sure its in good condition. i would bleed my lines for the slave cylinder (just cuz your messing with it some anyways). depending on how many miles yours have i would make sure to inspect for ware on the clutch fork and its pivot points (should be fine but worth checking out). and since u didnt say how many miles your clutch has i would say replace that and possibly your flywheel also, depending on the condition of it, basic stuff.
if you get the clutch fork from the other trans and its in better shape feel free to use it, they are identical.
99 Wrangler Sahara 5spd manual - Mine
08 Patriot sport 4x4 auto - Wifes
92 Cherokee Lorado auto - for when mine needs fixin/winter beater
Im sorry, some times i drink and post stupid comments.
Sandhara is offline
post #4 of 12 Old 12-01-2012, 02:39 PM
Sandhara
Whats wrong with your ax15?
Sandhara is offline
post #5 of 12 Old 12-01-2012, 05:02 PM
GrantLasson
I went the other direction in an '04. I used the same bell housing. Everything was a straight swap.
GrantLasson is offline
post #6 of 12 Old 12-01-2012, 05:52 PM Thread Starter
nbrege
nbrege's Avatar
2014 JK Wrangler
what about the position of the shift lever? are they in the same location?
nbrege is offline
post #7 of 12 Old 12-01-2012, 10:48 PM
joe_jeep
they are nearly identical size wise. the shifter will be in the same location. uses the same mount. will bolt to your skid without mods.
just bolt it in and go. buy a new mount! swap the clutch slave and master if they are not in perfect shape. might want a new clutch while your at it.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #8 of 12 Old 12-02-2012, 04:19 AM
herklord
Why not go 4550 much more beef
04 TJ Willys Edition 4.0 five speed, metal cloak front, groundpounder rear, zj tie rod, currie track bar, more to come
herklord is offline
post #9 of 12 Old 12-02-2012, 10:44 AM Thread Starter
nbrege
nbrege's Avatar
2014 JK Wrangler
I dont really need anything real beefy ... I just do light offroading at the most. Just looking for the easiest /cheapest fix.
nbrege is offline
post #10 of 12 Old 12-02-2012, 10:46 AM
Douglas S.
Douglas S.'s Avatar
1991
You've done this have you? It's not even close to bolt in.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #11 of 12 Old 12-02-2012, 04:21 PM
herklord
Did i ever say it was? Troll
herklord is offline
post #12 of 12 Old 12-02-2012, 04:37 PM
Douglas S.
Douglas S.'s Avatar
1991
Yes, I am certainly a troll for pointing out the absurdness of recommending a transmission that requires adapters
and custom mounts in a thread where the OP was asking about OEM replacement options.
