AX-5 shift lever installed wrong - help! - JeepForum.com
post #1 of 6 Old 07-19-2010, 02:50 PM Thread Starter
VetteMemphis
Just going back together after a frame swap where, among other things, I had the transmission out and removed the shift lever from it. No further work other than cleaning and a "rattle can overhaul" to the transmission.
With the skid plate installed, set the transmission over in the skid plate, then wheeled the frame under the Jeep.
Then, my son re-installed the shift lever but now we have a problem:
1st and 3rd want to wind up in the ashtray or somewhere forward of where they're supposed to stop so, obviously, we've installed the lever incorrectly.
What did we do wrong and is there a trick to finding the "sweet spot"?
Thanks, in advance, for your help.
VetteMemphis is offline
post #2 of 6 Old 07-27-2010, 12:09 PM Thread Starter
VetteMemphis
Btt
post #3 of 6 Old 07-27-2010, 12:20 PM
jeepwrangler97
jeepwrangler97's Avatar
are you sure you didn't mount the transmission in the wrong holes on the skid plate, I don't think there are many ways to mount the shifter wrong, you line all the holes up and everything should be good, make sure the ball part at the bottom of the shifter is where it's supposed to be, in the hole. Good luck, Im curious to see what the solution is.
jeepwrangler97 is offline
post #4 of 6 Old 07-27-2010, 12:32 PM Thread Starter
VetteMemphis
Positive. Will keep you posted. In the meantime, I've run across a thread in the CJ boards that I'm studying.
I'm hoping it's simply a matter of clocking the locking collar 180 out.
Should be able to get at it tomorrow evening - tonight's taken up with a separate but related project.
Thanks for responding.
post #5 of 6 Old 08-03-2010, 08:35 AM Thread Starter
VetteMemphis
DOH...
Should have dawned on me before this but it didn't...
With the motor out of the frame, the nose of the transmission is going to droop BECAUSE the little mount cushion is behind the transmission's center of gravity which, OF COURSE, will throw the shift lever forward in all positions.
Raise the input shaft to the height where it's gonna live with the motor in place, and everything becomes copacetic.
End of problem.
post #6 of 6 Old 08-03-2010, 07:34 PM
jeepwrangler97
Originally Posted by VetteMemphis View Post
DOH...
End of problem.
Glad to hear there weren't any big problems
ax-5 , ax5 , tranny , transmission , shifter , position , installed , TJ
AX-5 vs AX-15 Shift Lever Leans93 YJ Wrangler Technical Forum 9 01-22-2012 08:59 PM
What holds the shift lever onto the transmission shift stub? venturad YJ Wrangler Technical Forum 10 01-19-2010 08:31 AM
How to separate upper shift lever from lower shift lever??? rgs112 YJ Wrangler Technical Forum 3 08-11-2008 06:59 PM
Shift Lever Trevaller YJ Wrangler Technical Forum 6 08-17-2007 05:53 AM
Seperating shift lever SonofSam02 YJ Wrangler Technical Forum 8 04-13-2007 05:58 AM
