Auto Transmission shift lever bushing - JeepForum.com
post #1 of 7 Old 06-07-2018, 07:00 PM Thread Starter
rstulsaok
The shift lever on my 2006 TJ X Auto 4.0 went loose this evening. I found treads about the bushing at the transmission, but the cable was disconnected at the shift lever on mine. The bushing was cracked and no longer securing the cable. I cannot find a part number for that bushing - does anyone know if it is the same bushing as the cable connection under the jeep? Does anyone have repair suggestions? I made a temporary bushing with some rubber tubing, metal washer, and a zip tie, but it won't hold for too long.
Thanks
rstulsaok is offline
post #2 of 7 Old 06-08-2018, 04:22 AM
DBLJ
DBLJ's Avatar
Part number - 68137495aa
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #3 of 7 Old 06-10-2018, 10:19 AM
Vooodo1
I have the same problem all I need is this bushing. Wow.. great I thought I would have to get a new trans cable. So the bushing just pops in and your done? Thanks
2005 Rubicon Unlimited, Hard top, Auto, Solar Yellow
Vooodo1 is offline
post #4 of 7 Old 06-10-2018, 07:54 PM
RDPrimeaux
RDPrimeaux's Avatar
spray a little wd40 on it and pop it in place
2006 LJ Rubicon
RDPrimeaux is offline
post #5 of 7 Old 06-10-2018, 08:22 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
I recently had to replace the bushing, and had to go to the dealer, but they had it in stock - seems like it would be a part that would break often and therefore be in stock at most dealerships. I think it was 6 or 7 bucks. The bushing just snaps easily on the shift lever, and then the trans cable snaps onto the bushing.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #6 of 7 Old 06-25-2018, 06:51 PM Thread Starter
rstulsaok
fixed shift lever bushing
Thanks to all. Bushing ordered for about $3.00.
I found it easier to slip the bushing into the cable termination, and then squeeze it onto the post on the shift lever with some channel locks.
post #7 of 7 Old 06-26-2018, 06:10 PM
mrchief
Using the Crown P/N listed above I got a kit with difference size bushings in it from NAPA. Work great.
mrchief is offline
auto , bushing , shifter
