auto shifter won't release from park to drive - JeepForum.com
post #1 of 5 Old 08-08-2010, 01:06 PM Thread Starter
dk02wrangler
I saw this same problem somewhere on the forum a while back, can't find it. This weekend i took out the interior to herculine and today I bolted everything back in. I go to depress the button on the side of the auto gear knob and it will not move from park. However when i remove the knob and press down on the white stem, it will shift. HELP
Cheers,
Dan
dk02wrangler is offline
post #2 of 5 Old 08-08-2010, 02:11 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
You may need a new stem or make one from a plastic hanger or chop stick?...
Gone but not forgotten.
Knuckelhead is offline
post #3 of 5 Old 08-08-2010, 02:17 PM Thread Starter
dk02wrangler
the stem possibly snapped or is not hooked onto the right place? Starting to make sense...
Thanks Knuckelhead!
post #4 of 5 Old 08-08-2010, 02:37 PM
Knuckelhead
R.I.P. Knuckelhead
Your welcome. Post back as to what you find?...
post #5 of 5 Old 08-08-2010, 02:44 PM Thread Starter
dk02wrangler
Just found 2 different threads with similar problems, looks like the shifter stem (plastic piece) is broken. This means i'll have to buy a whole new assembly (stealership) or use my Macgyver skills and use a chop stick or a piece of plastic clothes-hanger to replace the stem with! WOOO
Cheers,
Dan
automatic , shifter , park , drive , transmission , tranny , tj , wrangler
Where is the shift cable adjuster release button on 97 TJ auto. (merged) phoneman91 TJ Wrangler Technical Forum 13 06-28-2010 01:19 PM
1990 YJ Auto, hard to shift into neutral or park from drive Nokinja YJ Wrangler Technical Forum 1 08-15-2009 08:30 PM
08' Sahara auto will not come out of park? xjtrailrider JK Wrangler Technical Forum 9 02-08-2008 12:51 PM
Rubicon auto won't go into park kpatrick TJ Wrangler Technical Forum 7 05-06-2006 12:11 AM
Shifter vibration on clutch release farmer-dave TJ Wrangler Technical Forum 7 05-16-2005 05:35 PM
