ARB Safari Snorkel Question - JeepForum.com
post #1 of 6 Old 07-14-2020, 05:26 AM Thread Starter
CoachDad
CoachDad's Avatar
I tried emailing sales at arbusa, but it's just shy of two weeks and no response from them yet.
Quadratec says on their product page that the ARB snorkel will only fit a 4.0 TJ without air conditioning. A customer asked about it, and they doubled down on their response.
I went to the ARB website, and it makes no mention of this incompatibility. I even downloaded the pdf instructions for the snorkel, and there is no mention there, either.
So I emailed ARB sales, but have received no response.
Does anyone have definitive personal knowledge of this? And has anyone else had similarly poor service from ARB? I had been considering purchasing a few of their higher dollar items, but am now wondering what kind of operation they are running.
Thanks
CoachDad is offline
post #2 of 6 Old 07-14-2020, 10:07 PM
Vinman
I’ve had an ARB snorkel on my 03 Rubicon, 05 Rubicon Unlimited and now my 06 Rubicon Unlimited. All with A/C.
The only difference in snorkels I have seen were related to the early vs later TJ and it had to do with the way the flex hose connects to the factory air box. On the earlier TJ‘s the airbox connection is made towards the front of the box whereas on the later models the connection is made towards the rear end of the box. The change is due to the change in alternator location.
FWIW, the snorkel kits designed for the later models should fit all years but the kits for earlier TJ’s will have to be modified to connect towards the rear of the airbox.
I’m referring to the 4.0 TJ’s and have no experience with the 4 cyl models.
Vinman is offline
post #3 of 6 Old 07-15-2020, 05:04 AM Thread Starter
CoachDad
CoachDad's Avatar
That's a great explanation, and exactly what I was looking for. Thank you!
CoachDad is offline
post #4 of 6 Old 07-15-2020, 06:09 AM Thread Starter
CoachDad
CoachDad's Avatar
Originally Posted by Vinman View Post
Ive had an ARB snorkel on my 03 Rubicon, 05 Rubicon Unlimited and now my 06 Rubicon Unlimited. All with A/C.
The only difference in snorkels I have seen were related to the early vs later TJ and it had to do with the way the flex hose connects to the factory air box. On the earlier TJs the airbox connection is made towards the front of the box whereas on the later models the connection is made towards the rear end of the box. The change is due to the change in alternator location.
FWIW, the snorkel kits designed for the later models should fit all years but the kits for earlier TJs will have to be modified to connect towards the rear of the airbox.
Im referring to the 4.0 TJs and have no experience with the 4 cyl models.
Did you find it difficult (or maybe not possible) to remove the passenger door with the snorkel installed?
CoachDad is offline
post #5 of 6 Old 07-15-2020, 07:50 AM
Vinman
I trimmed the threaded portion of the top hinge pin off and that allows to easily remove the door with the snorkel in place.
Vinman is offline
post #6 of 6 Old 07-16-2020, 02:08 AM Thread Starter
CoachDad
CoachDad's Avatar
I ended up getting an email response and apology from ARB. They confirmed that the later model TJs with the 4.0 have no fitment issues. They also confirmed what I had heard, that the snorkel interferes with the removal of the passenger door. They said that disconnecting the top mounting bracket (on the windshield frame) will allow the door to be removed.
Considering this, I went with https://www.extremeterrain.com/redro...6-j102772.html , an extremely similar offering from the Extreme Terrain house brand. It appears to be nearly identical, and for $99 compared to $400 plus for the ARB. Plus, the Red Rock version doesn't have the prominent safari logo on its lower base.
Thanks again for the great information.
CoachDad is offline
