Anyone know where I can find a O2 sensor pigtail for the wiring harness side? - JeepForum.com
post #1 of 10 Old 07-09-2008, 08:21 PM Thread Starter
Rafikie
Rafikie's Avatar
I may be able to patch mine up with epoxy, but if I can find a new one why not just change it. I've been looking around online for parts microfiche to try and locate the part but zero luck there too. Thanks in advance
2000 TJ WW build in progress
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #2 of 10 Old 07-09-2008, 08:24 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Patch it with epoxy? What's wrong with it? Are you talking about the wiring harness jack that the 02 sensor's plug seats into?
Jerry Bransford is offline
post #3 of 10 Old 07-09-2008, 08:32 PM Thread Starter
Rafikie
Rafikie's Avatar
When I pulled the transmission I unplugged the o2 sensor to make it a little easier to move the harness around, well the round cover that protects the 4 prongs fell off. I slid it back on after, but I'm just concerned about a future failure. Think it'll be fine with some epoxy though? It'll probably save me some coin which of course I'll just roll into some other part of the jeep Just for future info though. Do you know where I might be able to find odd items like that?
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #4 of 10 Old 07-09-2008, 08:42 PM
Jerry Bransford
Administrator
A future plug failure would, at most, mean the 02 sensor is going to set a code and maybe make the engine run rich, nothing major. Based on that, I'd epoxy it or tape it up without a moment's hesitation. Just make sure all the electrical connector pins are seated solidly before you do that. I'd probably look in a junkyard for one if I really wanted a new 02 sensor jack.
post #5 of 10 Old 07-10-2008, 06:09 AM
lloydsmale
2015 JK Wrangler
seal it with silicone
2015willys 4 cyl tj 2017 silverado yamaha grizzly, Polaris rzr 04 z06 vette, 600/800 crossfire cat
lloydsmale is offline
post #6 of 10 Old 06-09-2015, 07:21 PM
Scotch740
Scotch740's Avatar
Bringing this back to the top because I am looking for the oxygen sensor plug/pigtail on the wiring harness side. It appears the previous owner cut the connector off for some reason. Any help is greatly appreciated.
This is for a 98 TJ.
Scotch740 is offline
post #7 of 10 Old 06-09-2015, 07:41 PM
LJ Dave
Originally Posted by Scotch740
Bringing this back to the top because I am looking for the oxygen sensor plug/pigtail on the wiring harness side. It appears the previous owner cut the connector off for some reason. Any help is greatly appreciated. This is for a 98 TJ.
On my '05 4.0 liter there are 4 O2 sensors and on each one the connector is keyed with 3 unique slots on each connector so you can't install one in the wrong location. Just mentioning this so you get the right one.
2005 Rubicon LJ 4.5 inches of lift, 35's
LJ Dave is offline
post #8 of 10 Old 06-11-2015, 04:13 PM
Scotch740
Scotch740's Avatar
Earlier models have just one upstream and one downstream oxygen sensor. I need the pigtail for the upstream sensor located near the back of the manifold.
post #9 of 10 Old 06-11-2015, 10:59 PM
Twistedtrax
I found one at the junk yard and soldered the wires together, then heat shrink over it for my Dodge. You should be able to get odd parts like that off of other jeep models like the cherokee maybe.
Twistedtrax is offline
post #10 of 10 Old 06-12-2015, 10:51 AM
kpalm7
It's very overpriced ($35 or so if I remember correctly), but Chrysler does sell a replacement pigtail for the harness side. When I first got my LJ my connectors were melted from contacting the header, so that's the route I went. Still had four wires to solder, so I should have just gone to the junkyard.
'06 LJ, Supercharged, Coilovers, lockers, armor, and stuff. 37s.
kpalm7 is offline
OEM foglight switch and pigtail wiring Qs mithuth TJ Wrangler Technical Forum 4 01-23-2010 12:50 PM
any flatfender-ed guys got a spare fender wiring pigtail? LoneJeeper Wrangler General Discussion 6 12-14-2009 12:48 PM
Hardtop wiring pigtail question default TJ Wrangler Technical Forum 7 11-05-2008 06:08 AM
o2 sensor wiring harness Mfox98 TJ Wrangler Technical Forum 3 09-10-2007 03:43 PM
Hard Top Wiring Pigtail....... WranglerDan TJ Wrangler Technical Forum 0 11-15-2006 01:11 PM
