anti rock bushings - Page 2 - JeepForum.com
post #16 of 22 Old 11-14-2009, 11:03 PM
diablo_331
diablo_331's Avatar
Originally Posted by zachbh View Post
Yep, I'm set on tools. Let me know, good luck!
I don't think plastics will shrink significantly..... Metals will.
Thats what i did to get the bushings into my RC control arms...I stuck them in the deep freezer for an hour and they went right in..I believe the temperature was -30 degrees F.I guess it would be worth a try in this situation.
'01 TJ, Waggy 44 front, D44 rear, Both locked and loaded, Savvy Armor, SuperWinch LP8500, MetalCloak bumper, and a heavy foot.
diablo_331 is offline
post #17 of 22 Old 11-14-2009, 11:11 PM
zachbh
zachbh's Avatar
Well I stand corrected. I didn't think they would shrink that much. Next time I'll have to try that, thanks for the tip.
zachbh is offline
post #18 of 22 Old 11-14-2009, 11:13 PM
glockster
glockster's Avatar
Originally Posted by provelogear View Post
Marco,
That was quick! A little softer on road but well worth it on the trail.
Gerald
10-4 Gerald. Hopefully I'll get to find out first hand tomorrow on Cleghorn.
Marco
glockster is offline
post #19 of 22 Old 11-15-2009, 07:16 AM
robncar
robncar's Avatar
What hole are you running Marco?
https://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #20 of 22 Old 11-15-2009, 08:44 AM
Jeepish
1984 CJ8
When I put mine in, I lightly chamfered the holes in the frame rail and end of bushing. It was still a tight fit and required real beating with the wood block and hammer, but eventually it got in.
WTF-J - Bobbed Alu CJ-8 w/6.0L Gen-III, Atlas, AiRock, & ARB'd D60s
Jeepish is offline
post #21 of 22 Old 11-15-2009, 09:27 PM
glockster
glockster's Avatar
That's a good description of what I had to do also with the exception of the large ball of welding slag in the passenger side tube.
Marco
post #22 of 22 Old 11-15-2009, 09:32 PM
glockster
glockster's Avatar
Hi Rob.
Currently, 4th hole from the front, or if your a little goofy like me, 2nd hole from the back.
Marco
How in the *@(#!~ are you suppose to get the anti rock bushings in? WILLY348 TJ Wrangler Technical Forum 14 08-28-2012 10:45 AM
Anti sway bar....bushings? obcean YJ Wrangler Technical Forum 4 11-09-2008 09:23 PM
Anti-rock freedom5 TJ Wrangler Technical Forum 16 08-11-2006 01:42 PM
To those with the Anti-Rock... Achped TJ Wrangler Technical Forum 11 06-06-2006 07:31 PM
Those of you that have anti-rock for a TJ Harry Hood TJ Wrangler Technical Forum 15 02-10-2006 07:14 PM
