anti rock bushings - JeepForum.com
post #1 of 22 Old 11-14-2009, 06:39 PM Thread Starter
jeepy01
anti rock bushings
tired to install my anti rock today but could not get the bushing to fit into the front cross member. im planning on grinding them down a bit tommorow has anyone else had this problem.
jeepy01 is offline
post #2 of 22 Old 11-14-2009, 07:18 PM
lukethedork
As per the instructions. A block of wood and mallet should seat them in.
Mine were VERY tight, but I figure the tighter the better.
Also I remember reading somewhere if you have trouble getting them started then file the edges as to help it get started.
IMO I would not grind down the whole bush as it will likely make it too loose.
Luke.
lukethedork is offline
post #3 of 22 Old 11-14-2009, 07:32 PM
robncar
robncar's Avatar
Luke.
Yep, I agree, don't cut down the bushings. They need to be a tight press fit. Make sure that there are no burs on the frame tube. We were able to seat ours with a block of wood and a BFH.
https://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #4 of 22 Old 11-14-2009, 08:23 PM
zachbh
zachbh's Avatar
I just did mine the other day. Like everyone says, file down the burs, and maybe the corners on the bushing a little bit. They will fit though.
zachbh is offline
post #5 of 22 Old 11-14-2009, 08:26 PM Thread Starter
jeepy01
zach are you gona come tommorow if we dont get snowed out?
jeepy01 is offline
post #6 of 22 Old 11-14-2009, 08:31 PM
RubiconRazorbac
RubiconRazorbac's Avatar
OP, I just did this a couple weeks ago and like others have said, check for burs in the frame. Also, I know the directions say you may need to "tap" the bushings in, but there's no tapping about it. Get a 2x4 and BFH and beat the bushing into the frame. Same thing with the bar when you get the bushings installed. It'll take some force to get the bar through the bushings. Don't be shy. Just have everything lined up and apply some force to it.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #7 of 22 Old 11-14-2009, 09:24 PM
zachbh
zachbh's Avatar
If I don't have a late night tonight, get a second coat of paint on, yes maybe.
zachbh is offline
post #8 of 22 Old 11-14-2009, 10:21 PM
glockster
glockster's Avatar
Just did this last night. Had to get the die grinder out to remove a couple of welds from inside the frame tube. Then had to do a little relieving of the bushings. I used a 5lb hammer and there was no way they were going in without some massaging. My bigger problem was the Body Armor front bumper covering the tube. What a PITA.
Marco
glockster is offline
post #9 of 22 Old 11-14-2009, 10:23 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Marco,
That was quick! A little softer on road but well worth it on the trail.
Gerald
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #10 of 22 Old 11-14-2009, 10:27 PM Thread Starter
jeepy01
i tried everything, creased um up, pounded, pushed, but it still wouldnt even get started to go in.
jeepy01 is offline
post #11 of 22 Old 11-14-2009, 10:34 PM
zachbh
zachbh's Avatar
If you still have this problem tomorrow, let me know. I can help you if need be.
zachbh is offline
post #12 of 22 Old 11-14-2009, 11:07 PM Thread Starter
jeepy01
tommorow ill try to file the xmember down more and see if i can get it in. ill pm you or something i need the extra help, im tight on tools living in the dorm(no BFH). thanks for the offer to help.
jeepy01 is offline
post #13 of 22 Old 11-14-2009, 11:33 PM
diablo_331
diablo_331's Avatar
throw the bushings in the freezer...they could shrink slighly?? IDK.
'01 TJ, Waggy 44 front, D44 rear, Both locked and loaded, Savvy Armor, SuperWinch LP8500, MetalCloak bumper, and a heavy foot.
diablo_331 is offline
post #14 of 22 Old 11-14-2009, 11:45 PM
zachbh
zachbh's Avatar
Yep, I'm set on tools. Let me know, good luck!
I don't think plastics will shrink significantly..... Metals will.
zachbh is offline
post #15 of 22 Old 11-14-2009, 11:53 PM
06WranglerX
I used a wood maul with a large flat side, and a piece of oak larger then the bushing, it takes a few good wacks.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
How in the *@(#!~ are you suppose to get the anti rock bushings in? WILLY348 TJ Wrangler Technical Forum 14 08-28-2012 11:45 AM
Anti sway bar....bushings? obcean YJ Wrangler Technical Forum 4 11-09-2008 10:23 PM
Anti-rock freedom5 TJ Wrangler Technical Forum 16 08-11-2006 02:42 PM
To those with the Anti-Rock... Achped TJ Wrangler Technical Forum 11 06-06-2006 08:31 PM
Those of you that have anti-rock for a TJ Harry Hood TJ Wrangler Technical Forum 15 02-10-2006 08:14 PM
