Another Savvy idea, recipe for good steering - JeepForum.com
 8Likes
post #1 of 352 Old 06-30-2011, 03:37 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
I will add to this as we get more good pictures of parts. But, this should tickle some of you a great deal.
Take this-
Add some reinforcement to the outer faces-
Drill a hole for some more reinforcement-
Add another bracket to pick up the back side and clamp it to the axle tube-
Now you can anchor one end of the cylinder-
Throw some u-bolts through the spiffy little clamp, hook up some hoses-
Hook up the other ends of the hoses, tighten the clamp with the tires straight ahead, toss on your sticker to show how smart you are and you wind up with this. Almost Bolt-on Cylinder assist for the Currie Steering with some very Savvy parts from us and PSC.
A few preemptive answers.
No, it won't work with your stock steering linkage, stock pump, stock reservoir, or stock steering gear, don't even ask.
YES it must be run with our cooler set up and our very cool mount we built.
No you cannot yet get all the parts in one spot. You will order the Savvy Cylinder Assist kit from PSC and it will include the following-
Small bore steering gear that is already ported for cylinder assist.
Remote reservoir that has a -12 feed line port and a -8 return. (normal is -10 and -6) The feed line will only be offered at a max length of 14" so the reservoir will only be mounted as far from the pump as that allows.
Steering cooler that you will send to me and I will modify it to work with the mount. It will only come with -8 fittings and return line.
Specially modified 2206-Savvy cylinder with everything shortened to have a short collapsed length.
Cylinder hose and fittings field serviceable.
Pump with a -12 inlet and -6 pressure side.
hose for same
What you will get from us-
Cooler mount
cooler modification
Special -8 return line fitting into the steering gear
Special -6 pressure line fitting adapted to work with or without a body lift.
Reinforcement bracket package with hardware
Misalignment bushings that adapt the cylinder rod end into the stabilizer mount.
Draglink clamp mount with one new u-bolt as you will re-use the two u-bolts from your existing stabilizer mount from Currie and new lock nuts.
We will work on putting the whole package together if you desire it that way. We did it this way for those that already have the ported gear, pump, and reservoir and want to add assist.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #2 of 352 Old 06-30-2011, 03:59 PM
F9K9
F9K9's Avatar
OMG, Pure Wood!
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #3 of 352 Old 06-30-2011, 04:12 PM
TJeeper
TJeeper's Avatar
Where's the picture of the cooler and mount?
That's my next project, still figuring out how I want to do it.
Looking good Blaine, I know you've been thinking about this for a while.
Patrick
TJeeper is offline
post #4 of 352 Old 06-30-2011, 04:13 PM
flying_bosun
flying_bosun's Avatar
I have nothing intelligent to say, so I'll just
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #5 of 352 Old 06-30-2011, 04:23 PM
lumpster
lumpster's Avatar
Looks like an easy bolt on ram assist, that can be taken back off and moved to another jeep if you switch jeeps very often. What is the bore of the cylinder? for those of us that have never driven a jeep with ram assist, how does it change the way the steering feels?
Whats this setup cost? just curious, ill have to have something to save up for after i save enough for the 17 inch brake kit.
lumpster is offline
post #6 of 352 Old 06-30-2011, 05:00 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Thank you for putting this together! I've been watching for this and it looks like you've hit another home-run.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #7 of 352 Old 06-30-2011, 05:02 PM
Kiwi
Kiwi's Avatar
I'm tickled. Great to see this finally coming together Blaine.
Kiwi is offline
post #8 of 352 Old 06-30-2011, 05:09 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
I don't know the bore size and don't really care. If it were smaller it wouldn't work very well and if it were bigger, you'd need more pump. So, it's just right.
If you can tell there is cylinder assist while you're driving it on the highway, then you did something wrong.
Don't know the costs yet. That's the first one to be installed and it was done to check to see if the parts needed much refinement. There are a few issues that need to be dealt with minorly. The biggest one is the big bracket needs a fair bit of re-work to be more installation friendly.
I am Savvy
mrblaine is offline
post #9 of 352 Old 06-30-2011, 05:13 PM
RubiconRazorbac
Do we need to speak with any specific person at PSC to order, or is their part of the setup in full production?
2003 TJ Rubicon:
2017 JKU Rubicon:
post #10 of 352 Old 06-30-2011, 05:22 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
Lance at PSC will be the contact person for the kit.
I am Savvy
mrblaine is offline
post #11 of 352 Old 06-30-2011, 05:30 PM
JJeeper09
JJeeper09's Avatar
Very nice Blaine. Great setup. May be giving yall a call here soon
JJeeper09 is offline
post #12 of 352 Old 06-30-2011, 05:43 PM
55willystruck
Blaine-
Great to see this finally out. Looks great. Might be a bit, but I'll pick one up eventually... Great Job!!!
Best of Luck,
Mike
55willystruck is offline
post #13 of 352 Old 06-30-2011, 06:34 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Better get one ordered for the Test Mule!
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #14 of 352 Old 06-30-2011, 07:01 PM
jr03
"Special -6 pressure line fitting adapted to work with or without a body lift"
Is this to keep fitting from hitting the radiator on no lift applications? Reason I ask is I saw a fitting broken off a PSC pump by hitting radiator on a no body lift Jeep and I think they used a special elbow to gain clearance when fixing it.
jr03 is offline
post #15 of 352 Old 06-30-2011, 07:09 PM
hustler905
hustler905's Avatar
This is an excellent idea, once my steering box finally dies I will be looking to upgrade.
hustler905 is offline
Savvy Ultimate Currie Steering Kit question bbuske TJ Wrangler Technical Forum 3 12-06-2010 11:22 AM
Currie Steering..Savvy Steering, old tie rod GMC7000 TJ Wrangler Technical Forum 186 06-04-2010 08:13 AM
Savvy front bumper license plate mount idea? rastadog TJ Wrangler Technical Forum 7 06-03-2010 08:13 PM
Undercoating. Good idea or bad idea? fatjeepkid JK Wrangler Technical Forum 17 05-30-2010 08:17 AM
Herculining hard top... good idea? bad idea? ScottJ83 TJ Wrangler Technical Forum 19 10-27-2006 04:31 PM
