Ammo Can Console Build - JeepForum.com
post #1 of 9 Old 07-07-2010, 04:44 PM Thread Starter
Bill M.
Mods, move this if need be..
Hey everyone. So I know there are many build threads for the ammo can center console, but I haven’t found one that was detailed enough, so here is mine:
First, for the supplies:
1 .20mm ammo can
Plasma Cutter –or cut off tool
Rattle Can Primer
Rattle Can Paint
Square
Pencil
Measuring Tape
Self Tapping Screws
I chose to use the .20mm ammo can because it is large enough that it sits at the perfect height for an arm rest.
First of all, you are going to want to test fit the can in your jeep. I found that I was going to have to make a cut for the break handle and the mechanism. Here is a picture of the can before I went to work on it.
Notice on the first picture how I have the line drawn for the lever, and on the second picture how I have the lines for the parking brake mechanism. All of the measurements will be on the pictures.
The lever cut out will need to be 1 inch thick and 10 1/2 inches high. This will allow the lever to be pulled to its full height. This will vary depending on how far you want the console to be forward. I just had mine sit flush on the floor.
On the bottom on the lever slot, you will need to cut a slot that is 3 inches high, by 3 1/8 inch long. This will allow the can to clear the mechanism.
Cutting the lines with a plasma cutter made the job easy as pie. This was my first time using one, so the lines are perfectly straight, but they are pretty good. Haha notice how I wrote my name in one of the cut off areas to practice.
As for the hole on the bottom of the can to clear the mechanism, a 8 inch by 3 1/8 inch slot will need to be cut.
Next you’ll want to take a grinder and get all of the burrs off of the can. They will be sharp and could cut you or someone else.
Now, hit it with a coat of primer, and a coat or two of paint. I chose smoke grey, since I couldn’t find a charcoal grey at Wally World to match my interior.
After the paint dries, attach it to the body using self tapping screws.
I hope that this helps anyone who is unfortunate enough not to have a console. I love it because it makes a good arm rest. I plan to make a pad for the top of it in the future.
Originally Posted by mdm View Post
Avoid "Hey guys! Watch this!" situations. They tend to have bad endings.
Bill M. is offline
post #2 of 9 Old 07-07-2010, 05:16 PM
Polecat
Polecat's Avatar
Thanks for posting this. I have been considering this for a while. Does the can sit flat on the floor?
Polecat is offline
post #3 of 9 Old 07-07-2010, 05:28 PM Thread Starter
Bill M.
In my TJ it does. IIRC, it will need a bracket in a YJ.
Bill M. is offline
post #4 of 9 Old 07-07-2010, 05:38 PM
sicandtwisted
And to think i just sold 1 of those ammo cans for $1
sicandtwisted is offline
post #5 of 9 Old 07-07-2010, 05:42 PM Thread Starter
Bill M.
Bummer... try to get it back for $2!
Bill M. is offline
post #6 of 9 Old 01-10-2011, 09:24 PM
BallerJeep
sorry for reviving old thread, but can we get some pictures of it in? As in top view and such. Hows it work with your cup holders?
"Do not go where the path may lead, go instead where there is no path and leave a trail." - Ralph Waldo Emerson
BallerJeep is offline
post #7 of 9 Old 03-06-2012, 06:16 AM
FZY1
FZY1's Avatar
bump to find it easier.
FZY1 is offline
post #8 of 9 Old 03-06-2012, 08:15 AM
cvisinho
i went the extra mile on mine and made a top pad. Just a piece of 1/2 wood the same dimensions as the top, glued foam to it from the fabric store, wrapped it in black canvas and then secured it from inside the top with some screws.
way more comfortable than the metal.
cvisinho is offline
post #9 of 9 Old 03-07-2012, 08:11 PM
GREASEMONKEY
GREASEMONKEY's Avatar
The next can I get ahold of I'm gonna go a little more custom.
I'm gonna make a bracket for the E brake that should make it more accessible. I'll also make a pad for the top, and it will be side fold opening. I'll also reinstall my sub in the next one.
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
GREASEMONKEY is offline
console , center , ammo can , ammo box , mod , modification
Ammo Can Console j_bydesign TJ Wrangler Technical Forum 9 05-05-2010 09:43 AM
20 MM ammo can for console? Osso YJ Wrangler Technical Forum 18 10-14-2009 06:09 PM
5.56 ammo box console cresencio Wrangler General Discussion 2 01-18-2009 06:35 PM
Ammo Can Console Help . . . CallMeEddie TJ Wrangler Technical Forum 4 03-01-2004 11:10 PM
Ammo Box Console AK1904 YJ Wrangler Technical Forum 11 01-31-2004 07:30 PM
