Almost lost my spring! What now? - Page 3 - JeepForum.com
Closed Thread
post #31 of 116 Old 10-10-2012, 11:50 AM
dcope17
dcope17's Avatar
Jeep supported by 3 wheels and an essentially missing 4th spring. 4th tire off and the axle on a bottle jack with maybe a 2" round surface holding the axle. Kick the high lift out, watch the spring compress from the drop and shoot out the reas of the way, then to the bumpstop all that jolt supported by a 2" round flat disc on a piece of tubing.
Not trying to make it too dramatic. But a high lift is never a trusted piece of equipment.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #32 of 116 Old 10-10-2012, 11:56 AM
TheRealKTrain
JK Wrangler
Agreed. I dont have a dog in this fight, I just wanted to play devil's advocate
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #33 of 116 Old 10-10-2012, 12:19 PM
scottbr
scottbr's Avatar
2016 JK Wrangler
There's usually a metal tab on just one of the front springs and nothing else.
I'm still shaking my head on that one. Why bother if you're only going to put it on one spring?
Maybe something to do with the way they installed the axles at the factory, clocking the springs or something.
Originally Posted by -Deepskyy- View Post
We've made the world idiot proof, and now its full of idiots.
scottbr is offline
post #34 of 116 Old 10-10-2012, 01:07 PM
AtomicDog
Originally Posted by dcope17 View Post
You lifted your vehicle with a high lift then crawled under it with a cockeyed spring and unbolted the shock.
What an idiot. I'd hate to see how you fix things on the trail with fewer tools and likely in a hurry.
Wow. I would not have expected such a harsh response based on your signature. Maybe it wasn't meant as strong as I read it. I do, however, know of someone who died from an incorrectly supported vehicle landing on thier chest, so maybe harsh is good...
Warranty and customer service won't matter if your equipment fails during a zombie attack.
Torture numbers long enough and they'll tell you what you want to hear.
cq cq KI4DOG
AtomicDog is offline
post #35 of 116 Old 10-10-2012, 01:11 PM
JeffBowser
JeffBowser's Avatar
I was thinking the same thing.
JeffBowser is offline
post #36 of 116 Old 10-10-2012, 01:13 PM
biffgnar
biffgnar's Avatar
Didn't the factory eventually stop bothering? I don't think my 06 had one and was under the impression that was common in late models.
biffgnar is offline
post #37 of 116 Old 10-10-2012, 02:01 PM
dcope17
dcope17's Avatar
Maybe that was a bit harsh... but I really couldn't believe what I was reading.
Spring issue aside. Grab the roll bar and give it the push pull test before trusting anything and that this would have come all the way down. Axle to pavement. Sorry for the verbal abuse but don't ever do that again.
dcope17 is offline
post #38 of 116 Old 10-10-2012, 02:06 PM
clg82
don't worry about verbal abuse...jesus forgives for everything right?....so you're safe.......praise the lord.
clg82 is offline
post #39 of 116 Old 10-10-2012, 02:24 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It has to do with the way the lower perch is formed. The pigtails are rotated 180 degrees from each other and the tab holes are mirrored. That means one tab grabs onto the end of the dead tail which doesn't move and the other side is trying to clamp down on a live part of the spring which moves.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #40 of 116 Old 10-10-2012, 04:55 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
It's a sign from above that it's Tebow time for the Jets.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #41 of 116 Old 10-10-2012, 05:19 PM
DevilDogDoc
My 97 has them on both front springs FWIW.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #42 of 116 Old 10-10-2012, 05:32 PM
Robert J. yates
LOL... with Keith02's threads all closed down, I was hungry for some drama and guess what... JF to the rescue.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #43 of 116 Old 10-10-2012, 06:03 PM
LiveAndLearn
LiveAndLearn's Avatar
Originally Posted by vic_sinclair View Post
Your garage has a parquet floor?
exactly what I was thinking.
classy.
LiveAndLearn is offline
post #44 of 116 Old 10-11-2012, 01:12 AM
nectoxicdragon
I think he cancelled his JF membership and joined Wrangler forum by now.
Tell you what horses *** When youve had HALF the experience I have come bacl and talk to me... until then continue showing your ignorance and stupidity, and go jack up a jeep and unbolt the shocks and see what happens, then go do a little research on metallurgy and and learn about the rockwell hardnes scale and how it relates to spring steel and brittleness. I've been doing this since you were still in diapers and probably before, as illustrated by your abject stupidity and flagrant ignorance
nectoxicdragon is offline
post #45 of 116 Old 10-11-2012, 01:17 AM
nectoxicdragon
Originally Posted by Barcus View Post
bumpstops and/or limit straps.
There are no limit straps on a jeep suspension and bump stops only prevent the upward travel of the axle not the downward. You idiots really need to learn automotive engineering before shooting off your mouths.
Closed Thread
