Almost lost my spring! What now? - JeepForum.com
Closed Thread
post #1 of 116 Old 10-10-2012, 02:43 AM Thread Starter
T-Jay
T-Jay's Avatar
I just noticed by shear luck that my drivers side rear spring is sitting precariously half off the lower bucket. How do I get it back in place without killing myself. Can I use my highlift jack to lift the jeep up as high as possible and pull it back in line with some rope or something?
My Surgical TJ-6 Build
T-Jay is offline
post #2 of 116 Old 10-10-2012, 04:17 AM
TheBoogieman
Democrat's 2020 NIGHTMARE
TheBoogieman's Avatar
Lift up your Jeep,let the axle droop and smack the spring with a hammer or pry it back in place.It should go in place very easily.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #3 of 116 Old 10-10-2012, 04:24 AM Thread Starter
T-Jay
T-Jay's Avatar
Ya beat me to the post lol. That's exactly what I did.
Scary!
T-Jay is offline
post #4 of 116 Old 10-10-2012, 04:28 AM Thread Starter
T-Jay
T-Jay's Avatar
Thanks for the tip though
T-Jay is offline
post #5 of 116 Old 10-10-2012, 04:33 AM
pmcjeep
Scary!
Looks like you need to buy or build some retainers!
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline
post #6 of 116 Old 10-10-2012, 04:41 AM
nectoxicdragon
WTF? WRONG!!! support the axle with the wheel off, unbolt the shock at the bottom and then LIFT the body carefully, (watch the break line) you shold be able to push the spring back in place with minimal force. But NEVER STRIKE a SPRING. They are HARDENED and CAN CRACK, start a hairline crack in one and you can have that beast fail on you when you least want it to, and end up rolling over... and not just a simple flop either. With as much pressure off it as you can get you may be able to simply pry it over, if you can just push it, its time to look at new springs, Also check those shocks, they are supposed to act to limit downward axel movement, if you have the wrong ones in place (too long) this can happen again, I dont believe in bolting coil springs to the lower perch but some people have done this... On my lift the rear springs got a touch rattly, I was told to use a pair of cable clamps on both sides... drill the perch accordingly,,, As I said, I dont buy into it. I just cut a ciuple pieces of black garden hose and slipped it over the bottom coil and it went silent... BUT you do have an issue you need to check,,, start with the shocks.
nectoxicdragon is offline
post #7 of 116 Old 10-10-2012, 06:35 AM
njrealtor55
njrealtor55's Avatar
currie bumpstops w/ built in spring retainers (sold at savvy offroad) will stop that from happening again.
Jason
04 Rubicon mallcrawler
savvy/currie 4"
njrealtor55 is offline
post #8 of 116 Old 10-10-2012, 06:40 AM
TheBoogieman
Funny,but very stupid.
p.s. Jeeps don't have break lines.
post #9 of 116 Old 10-10-2012, 06:59 AM Thread Starter
T-Jay
T-Jay's Avatar
This is essentially what I did.
1) I disconnected the front sway bar,
2) High lifted the jeep at the rear DS bumper.
3) Took the wheel off.
4) bottle jacked the brake drum up an inch or so.
5) Unbolted the shock absorber.
6) Eased the jack down.
Then I (tapped) the coil spring back with a (rubber) mallet. It didn't take much at all. I might have even been able to rip it back on by hand if I had a good leverage point.
As far as the shocks, They actually are the correct length. The spring didn't pop out on its own. My buddy and I installed an adjustable rear track bar yesterday. I think what happened is that we got distracted by a tailpipe clearance issue on the passenger side and didn't notice that the spring was not seated properly when we put everything back together. The beers didn't help either I guess. Stupid mistake on my part. I should have checked everything over when we were done. I've actually ordered the Currie spring retaining bumpstops for when I outboard my shocks.
Thanks for the info. I didn't realize you weren't suppose to hit the springs with a hammer. I uses the rubber mallet because it was within reach.
T-Jay is offline
post #10 of 116 Old 10-10-2012, 07:09 AM
TheBoogieman
According to nectoxicdragon, your Jeep will now fall apart.I'm sure nobody has ever hit their springs on a rock,EVER.
post #11 of 116 Old 10-10-2012, 07:16 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Springs are hardened, but what do they do to good ones afterwards? I'll give you a hint, it involves hitting them with steel and a lot of force.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #12 of 116 Old 10-10-2012, 07:43 AM
vic_sinclair
Your garage has a parquet floor?
vic_sinclair is offline
post #13 of 116 Old 10-10-2012, 07:49 AM Thread Starter
T-Jay
T-Jay's Avatar
LOL! And a giant chandelier over the wet bar. Na. Those are just crappy old glue down linoleum floor tiles.
T-Jay is offline
post #14 of 116 Old 10-10-2012, 08:22 AM
JeffBowser
JeffBowser's Avatar
I keep waiting for someone to tell dragon boy that shocks aren't supposed to serve as travel limiters, either.
JeffBowser is offline
post #15 of 116 Old 10-10-2012, 09:41 AM
TheBoogieman
I think he cancelled his JF membership and joined Wrangler forum by now.
Closed Thread
