All About Roll Cages For TJ/LJ - Page 69 - JeepForum.com
View Poll Results: Which Rollcage Do You Prefer?
A to Z 57 11.40%
Rock Hard 105 21.00%
Poison Spyder 166 33.20%
OR-FAB 52 10.40%
Koz 25 5.00%
Poly Performance 95 19.00%
Voters: 500. You may not vote on this poll
 8Likes
post #1021 of 1055 Old 01-01-2019, 08:24 PM
toximus
I switched over to the passenger's side. Everything seems like it's lining up great over there.
Back to the driver's side I heated and moved the ductwork slightly to give more room for the lower A. When I place the upper A on the driver's side it seems that it is ever so slightly too long and doesn't sit nicely against B.
Do you guys have pictures of where the A pillar sits against the floor?
Building the right way for 37s.
toximus is offline
post #1022 of 1055 Old 01-01-2019, 09:37 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
He are a couple from my setup, which was all custom. I had to clearance the floor a bit to allow for the foreword placement of the floor plate. I was able to position the A-pillar back far enough that it did not interfere with the duct work.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is online now
post #1023 of 1055 Old 01-02-2019, 08:34 AM
toximus
Thanks Nash. I was worried at first that I was doing more cutting and massaging than I should be. I'm fine with that but wanted to make sure I wasn't completely missing how it's supposed to go together. It sounds like my install is pretty much par for the course.
I was thinking about adding in quick disconnects like you have there too.
toximus is offline
post #1024 of 1055 Old 01-02-2019, 12:07 PM
NashvilleTJ
I miss the snow...
I did that specifically so I can remove the cage without having to completely remove the dash.
Build Thread:
post #1025 of 1055 Old 01-02-2019, 07:40 PM
toximus
I think I'm starting to get this figured out a little more a little massaging at a time. There is a 1/2" difference in the factory rollcage to the windshield from driver's to passenger side. Looking at the takeoff door tubes it looks like the factory had built in a sliding adjustment to account for that and sure enough, they're different lengths. And they don't appear to have ever been adjusted so I think it's safe to assume they came from the factory this way.
It feels a bit hackish, but is the best course of action here to cut one of the A piller tops shorter so it fits?
toximus is offline
post #1026 of 1055 Old 01-02-2019, 09:23 PM
NashvilleTJ
I miss the snow...
Easier to fit the cage to the Jeep, than to fit the Jeep to the cage....
I assume that the top and the doors fit correctly?
Build Thread:
post #1027 of 1055 Old 01-02-2019, 09:31 PM
toximus
It always amazes me how much is different across Jeeps.
Driver's door isn't perfect but I'm 99% sure it's the door (door's bowed as far as I can tell, not the tub, it suddenly stopped closing one day years ago at a parking lot and I never have figured out what happened to it. After adjusting the hinges I have gotten it to function just fine.). Both tops fit great.
toximus is offline
post #1028 of 1055 Old 01-03-2019, 08:22 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Is the driver's side the one I saw a picture of with the crumpled front fender?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #1029 of 1055 Old 01-03-2019, 08:43 AM
toximus
Yes.
toximus is offline
post #1030 of 1055 Old 01-03-2019, 09:08 AM
toximus
Well sure enough, the door frame is bent just slightly. The door openings themselves are within 1/16" of each other, but they are positioned 1/8" different (driver's being rearward). That angle must extend up to the windshield peak to account for an entire 1/2".
Since everything currently fits and functions and works in this position and even knowing it's skewed it still isn't noticeable visually, I will just account for it with the cage.
toximus is offline
post #1031 of 1055 Old 01-04-2019, 10:03 AM
toximus
I was thinking about this again today. The smashed fender happened 2 months after the door started having trouble iirc. So I'm back to not knowing exactly how it happened just that it happened.
toximus is offline
post #1032 of 1055 Old 01-04-2019, 02:22 PM
rficken42
rficken42's Avatar
does anyone have photos of the Genright TJ Laser Notched Full Roll Cage Kit installed ?
99TJ 5.2V8 ax15 2.5lift dana30/44 Lockers 410s 35s AtlasII bellyup skid & winch
rficken42 is offline
post #1033 of 1055 Old 01-05-2019, 01:04 PM
toximus
I got it fully mocked up and removed again to double check the door surrounds to factory.
My door surrounds on both sides are angled down in the front with the Poly cage. The doors still shut.
Has anyone else had this problem?
toximus is offline
post #1034 of 1055 Old 01-05-2019, 01:17 PM
toximus
That must be the trick, start with the door surrounds and work out. I'm trying that!
toximus is offline
post #1035 of 1055 Old 01-05-2019, 08:50 PM
toximus
That was the trick! So much better now!
NashvilleTJ likes this.
toximus is offline
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Vinman
Poison Spyder YJ Trail Cage - anyone have one of these? Matt Graham YJ Wrangler Technical Forum 28 10-18-2008 02:43 PM
Here is my Poison Spyder cage IGotADisneyJeep TJ Wrangler Technical Forum 20 02-22-2008 07:49 PM
poison spider trail cage issue dankeenan YJ Wrangler Technical Forum 7 12-13-2007 10:26 PM
Poison Spyder Full Cage... Just about done! ONE JEEPBRO TJ Wrangler Technical Forum 67 05-02-2006 09:45 AM
