Airbags from a 97 on a 99 - JeepForum.com
post #1 of 4 Old 02-15-2006, 07:49 AM Thread Starter
red99tj
red99tj's Avatar
I need new airbags cause I recently got into an accident. I found a guy selling his airbags from a 1997 Wrangler for a lot cheaper than what I would have to buy them for new. The only problem is that the steering wheels are different styles. So Im guessing his airbags wouldnt fit into my 99 Wrangler correct? If he sells me his steering wheel also, will these work in my jeep?
I just want to make sure the airbag setup is compatible between 1997 and 1999 Wranglers before I buy them from this guy.
Thanks,
Mine (minus the cruise control)
His:
Frank
red99tj is offline
post #2 of 4 Old 02-15-2006, 10:53 AM Thread Starter
red99tj
red99tj's Avatar
ttt:...........................
Frank
red99tj is offline
post #3 of 4 Old 02-15-2006, 01:59 PM Thread Starter
red99tj
red99tj's Avatar
1 more time
Frank
red99tj is offline
post #4 of 4 Old 02-16-2006, 05:38 AM
baggerman1
Guest
I do not know if this will help you, but the part number for the airbag for a '97 is 5DS48TAZ whereas the part number for your '99 is 5GC51LAZAB. In '97, there was no cruise control offered on the TJ, '98 was the first year for that option and that is when the part number for the airbag changed to 5GC51LAZAB. However, all three years used the same clockspring -56009070AB if the TJ was not equipped with CC . If your '99 has cruise, then the clockspring is 56009071AB. I hope this helps you somehow. I would imagine the only difference in the clocksprings is the number of plug-ins to allow for the CC.
baggerman1 is offline
what do you do with airbags? 02OlllllllOTJ TJ Wrangler Technical Forum 31 12-29-2009 05:34 PM
Airbags RH31379 YJ Wrangler Technical Forum 3 04-14-2008 07:36 AM
Tj Airbags Nahkohe TJ Wrangler Technical Forum 21 02-19-2008 09:12 PM
Airbags gatorbait TJ Wrangler Technical Forum 3 12-06-2007 01:20 PM
Help-Airbags? Poseidon17 YJ Wrangler Technical Forum 5 07-27-2001 03:18 PM
