Air bag warning light stays on - JeepForum.com
 1Likes
  • 1 Post By mukluk
post #1 of 12 Old 04-03-2018, 06:34 PM Thread Starter
Straight6
01' Sport 4.0/5sp 110,000 mi
My airbag warning light was coming on intermittently but now stays on is there anyway to determine the problem without going to a dealer?
Straight6 is offline
post #2 of 12 Old 04-03-2018, 06:46 PM
cmarshand1
Happened to my 2000 and it ended up being the clock spring behind the steering wheel
Sent from my iPhone using Tapatalk
cmarshand1 is offline
post #3 of 12 Old 04-03-2018, 06:51 PM Thread Starter
Straight6
cmarshand1, how did you find the problem?
post #4 of 12 Old 04-03-2018, 06:52 PM
cmarshand1
Replaced everything the code reader at my moms dealership said it was to fix the codes and it ended up being the clock spring behind the steering wheel
post #5 of 12 Old 04-03-2018, 06:53 PM
cmarshand1
And theyíre not that expensive
post #6 of 12 Old 04-04-2018, 02:58 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
2018 years old
CMARSHAND1'S JEEP
User Has Not Filled Out Jeep Information.
Knuckelhead is offline
post #7 of 12 Old 04-05-2018, 05:34 PM
cmarshand1
Originally Posted by Knuckelhead View Post
2018 years old
CMARSHAND1'S JEEP
I think I finished the jeep info. If not let me know thanks
post #8 of 12 Old 04-06-2018, 04:48 PM
Knuckelhead
R.I.P. Knuckelhead
Nothing is filled out except your 2018 age. If it was filled out properly it would show up in your profile...
post #9 of 12 Old 04-06-2018, 05:16 PM
cmarshand1
If you could take screenshots of what Iím supposed to click on because I donít think I can find what yíall are talking about to fill this out I added a picture and filled out something it made me change my password twice and every time I go to get in it itís not saving the changes and I cannot find a save button
post #10 of 12 Old 04-06-2018, 05:17 PM
cmarshand1
If you need my email is [email protected]
post #11 of 12 Old 04-06-2018, 07:05 PM
mukluk
mukluk's Avatar
During normal operation of the airbag control module, the warning lamp will illuminate for seven seconds as a bulb check feature then turn off -- the ACM subsequently monitors the wiring/circuitry for the two airbags as well as performs self checks. If any problems are detected, the ACM will illuminate the airbag warning light. The airbag system is normally a very reliable one, rarely giving any faults or issues, the one exception being the clockspring. The clockspring serves as the contact between the electrical components located in/on the steering wheel and the rest of the body; problems will often arise due to water or foreign matter intrusion. Things you can do yourself would be to verify the airbag fuses are present and in good condition in the fuse block, and you can check that the connectors for the ACM, airbags, and the clockspring are clean and solidly mated. **WARNING** make sure you disconnect the battery and let the Jeep sit for at least ten minutes before messing with any airbag system connectors or fuses. If you can't find anything wrong with the fuses or connectors, the problem most likely is due to a bad clockspring, but it couldn't hurt to have the dealership or somebody with a DRB scan tool see what fault codes are kicking out.
cmarshand1 likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #12 of 12 Old 04-07-2018, 02:58 AM
Jonny Jeep
Jonny Jeep's Avatar
Try this...
https://www.jeepforum.com/forum/profile.php?do=extra
Jonny Jeep is offline
