advice on running 35's - Page 7 - JeepForum.com
post #91 of 99 Old 07-24-2010, 09:29 PM
emev0l
Originally Posted by Knuckelhead View Post
With some minor modifications, Ford Explorer rear disc brakes work very well on my 9"...
He doesn't have a 9" he has a D44, what do you suggest for that?
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #92 of 99 Old 07-24-2010, 09:43 PM
emev0l
With 35" tires, It would be a very good idea to upgrade the stock steering...IMO
Please quote my entire sentence, please do not erase the comma and the second half of the sentence and add a period.
That's taking things out of context.
You made it look like I said there is never a need to upgrade your steering.
emev0l is offline
post #93 of 99 Old 07-24-2010, 09:48 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Originally Posted by emev0l View Post
You don't need to upgrade the steering, but if you wheel pretty hard then your going to eventually kill your stock steering.
Currie's setup is the best solution, some people run a ZJ tie rod, it's larger then a TJ's.
You stated "You don't need to upgrade the steering", I don't agree with that...
Gone but not forgotten.
Knuckelhead is offline
post #94 of 99 Old 07-24-2010, 09:53 PM
Knuckelhead
R.I.P. Knuckelhead
Did I say he had a 9" axle? No. I don't run a D44. I still state that if he upgrades the front brakes due to larger tires, he will benefit by upgrading the rear brakes also...
post #95 of 99 Old 07-24-2010, 09:55 PM
inglisleslie
ebs yellow brake pads up front
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> https://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #96 of 99 Old 07-24-2010, 09:56 PM
emev0l
I have no problem with you disagreeing with anything at all, I want you to voice your opinion on everything, that's what the forum is all about, just please do not quote half of a sentence I write and add a period.
If you wheel a TJ with stock steering it's going to get beat up.
If you drive it on the street and baby it down the trails your going to be fine.
Would I rather he upgrade his steering? Yes
I didn't say, don't do it, it's a waste of money. I said if you wheel hard your going to have problems.
emev0l is offline
post #97 of 99 Old 07-24-2010, 09:59 PM
emev0l
How should he upgrade the rear brakes? Are you saying better pads or?
emev0l is offline
post #98 of 99 Old 07-24-2010, 10:14 PM
Knuckelhead
R.I.P. Knuckelhead
That's for the people running D44's to work out. As stated, I don't run one.
If I ever do, I'll work on that...
post #99 of 99 Old 07-24-2010, 10:19 PM
mgoodric
mgoodric's Avatar
FWIW I am running 35's on a D44 rear and a D30 front. No lift. I am running Metal Cloak Arched Tube Fenders, and rear corners however. I have not upgraded my steering or brakes yet, but plan to. I wheel every few weekends, but its mostly a daily driver.
03 Sahara 4.0 5spd - MetalCloak Arched Tube Fenders, MetalCloak Rear Corners, MetalCloak Rocker Rails Cobra 75 WX ST, Goodyear Wrangler MT/R with Kevlar, Rough Country 2.5" Long Arm, LoD Xpedition Series Bumper/Tire Carrier w/Trail Package
mgoodric is offline
35 , lj , wrangler , regear , vanco , brakes , advice
anyone running 35's with 4:10s on a 2.5l? Unii YJ Wrangler Technical Forum 6 05-01-2010 07:12 PM
running on 35's... dwillz07 TJ Wrangler Technical Forum 9 03-21-2008 09:21 AM
running 35's dire TJ Wrangler Technical Forum 21 11-28-2006 02:50 PM
RE 4.5 no bbl and running 35's Red Rubycon TJ Wrangler Technical Forum 2 10-24-2004 01:30 PM
