advice on running 35's - Page 6 - JeepForum.com
post #76 of 99 Old 07-03-2010, 08:51 AM
Apex
Recon death squad
Apex's Avatar
Originally Posted by Squint77 View Post
agreed. remember that you can put a auto in nuetral just like a manual transmission.
Which is awesome on a steep downhill...then you are FULLY relying on your less than efficient brakes. Which if they fail, you are now a bat out of hell for the remainder of the hill.
Apex is offline
post #77 of 99 Old 07-03-2010, 09:04 AM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Shift it back into gear if there's a brake problem...
Gone but not forgotten.
Knuckelhead is offline
post #78 of 99 Old 07-03-2010, 07:07 PM
Squint77
Squint77's Avatar
exactly. with a manual transmission you would shift back into gear just the same. Not sure why there should be a difference there.
Squint77 is offline
post #79 of 99 Old 07-03-2010, 10:08 PM
Apex
Recon death squad
Apex's Avatar
Or upgrade your brakes and quit worrying about it.
Apex is offline
post #80 of 99 Old 07-03-2010, 10:26 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Yeah, but that makes too much sense...
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #81 of 99 Old 07-04-2010, 09:12 AM
Knuckelhead
R.I.P. Knuckelhead
I did, 5 years ago...
post #82 of 99 Old 07-04-2010, 09:50 AM
Apex
Recon death squad
Apex's Avatar
I will...when I can afford it
Apex is offline
post #83 of 99 Old 07-24-2010, 05:45 PM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
I hate to bring back my old thread, but ive got the 33 vs 35s flu but i know i want 35s but three questions
a) will my mpg change alot between 35s and 33s even though im running 4.88s for both?
b) will i be ok running 35s on the d30 for street use for now and put it alloys and vanco front and rear when i can afford it?
c)is it roughly $900 for the vanco kit for just 2 calipers,rotors and so on?not for four?
APEDZ04LJ is offline
post #84 of 99 Old 07-24-2010, 06:04 PM
emev0l
a) It won't be a huge mileage change since your already geared pretty well.
b) You should be fine with stock shafts on the street.
c) Yes, just the front brakes, but rear brakes are only 30% of the braking power, fronts are 70%, your stock rear brakes are more then fine.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #85 of 99 Old 07-24-2010, 06:25 PM
Knuckelhead
R.I.P. Knuckelhead
After installing better brakes on the front axle with bigger tires, installing better brakes on the rear axle helps too...
post #86 of 99 Old 07-24-2010, 06:43 PM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
so if i did vanco front ebs green or yellow pads rear i dont know which yet, that will work,alsofor trails what would i need to upgrade other then steering?
post #87 of 99 Old 07-24-2010, 06:58 PM
emev0l
What better brakes do you suggest he install on the rear axle?
emev0l is offline
post #88 of 99 Old 07-24-2010, 07:01 PM
emev0l
You don't need to upgrade the steering, but if you wheel pretty hard then your going to eventually kill your stock steering.
Currie's setup is the best solution, some people run a ZJ tie rod, it's larger then a TJ's.
emev0l is offline
post #89 of 99 Old 07-24-2010, 07:23 PM
Knuckelhead
R.I.P. Knuckelhead
With some minor modifications, Ford Explorer rear disc brakes work very well on my 9"...
post #90 of 99 Old 07-24-2010, 07:26 PM
Knuckelhead
R.I.P. Knuckelhead
You don't need to upgrade the steering.
With 35" tires, It would be a very good idea to upgrade the stock steering...IMO
35 , lj , wrangler , regear , vanco , brakes , advice
anyone running 35's with 4:10s on a 2.5l? Unii YJ Wrangler Technical Forum 6 05-01-2010 06:12 PM
running on 35's... dwillz07 TJ Wrangler Technical Forum 9 03-21-2008 08:21 AM
running 35's dire TJ Wrangler Technical Forum 21 11-28-2006 01:50 PM
RE 4.5 no bbl and running 35's Red Rubycon TJ Wrangler Technical Forum 2 10-24-2004 12:30 PM
