advice on running 35's - Page 2 - JeepForum.com
post #16 of 99 Old 07-01-2010, 08:07 PM
jeepinmichguy_
jeepinmichguy_'s Avatar
yes you can, its better than stock.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #17 of 99 Old 07-01-2010, 08:22 PM
Dgaunt1
Dgaunt1's Avatar
I have a 3" Full Traction lift, a 1" body lift, and 33s. In my opinion, there is plenty of room for 35s. I also have the Xenon flat flares though, so I have a bit more "visual" clearance than you would have with your flares.
After the lift I had some vibes that were not fixed by the transfercase drop. I tried a motor mount lift, but nothing changed, so I ended up getting the sye. I still have stock control arms except for the rear upper ones, and my tires are still pretty well centered in the wheelwells.
From what I have read on the forum, a zj tierod is a good upgrade. Before the Currie kit came out, a zj tierod was the bees knees.
Dgaunt1 is offline
post #18 of 99 Old 07-01-2010, 08:26 PM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
ok guys im gonna throw a list together of all the parts and in what order im gonna do them and ill post it later, thanks for all the help guys, i finally made up my mind after 6 months of back and forth
APEDZ04LJ is offline
post #19 of 99 Old 07-01-2010, 08:34 PM
95wrangler4life
95wrangler4life's Avatar
Originally Posted by red rubi View Post
I don't know why people give this sage advice.
If you're going to do 35's do it right!
I love this saying, do it right! Who makes it right? Oh them peoples running around with tons of money to drop.
Originally Posted by jeepinmichguy_ View Post
read the i want to run 35's on my tj thread like above said. after that if you have questions feel free to ask but there is already some bad advice floating around this thread. that thread by nevermonday is spot on.
Bad advice, checking your profile says your Yj is on 35s, but not a TJ, your TJ's been on 33s, I have ran my TJ with 4.56 gears, 38 12.5 15 TSL SX's, 6.5 custom suspension and STOCK STOCK STOCK brakes and as the other poster said, stopped better than some of the stock vehicles. So i love how people say its bad advice. Rather spend money on a SYE if need be then upgrade brakes that may not need it. Does it hurt for each person to try and see what they think!
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #20 of 99 Old 07-01-2010, 08:43 PM
Apex
Recon death squad
Apex's Avatar
I run 35" tires on stock brakes...I leave plenty of distance between me and the car in front of me because I KNOW my braking power is diminished. I can stop pretty good if I shock the brakes, but if I am running the brakes and then NEED to stop I am kinda screwed.
ALSO...With an automatic and stock brakes, good luck offroad. Ask the guys I ran with this past weekend, I can push through my brakes on a steep descent.
I would love the Vanco BBK...I hate being a run away train on a downhill. (sure I can flick it into neutral and come to a stop, but I'd rather not have to 100% rely on my brakes.)
Apex is offline
post #21 of 99 Old 07-01-2010, 08:45 PM
jeepinmichguy_
the other poster's jeep probably stops better because he needs brakes on the gc. you want to try and get in a debate thats fine, i didnt call you out personally, but you give some horrible advice. who cares what i have on 35's its the same thing (you know that though because you had a tj and now own a yj). things need to be upgraded to run it properly. i know how to build both a tj and a yj. running 35's needs pretty much the same junk. he probably wont need a sye with the 3 inch lift, he may but as you know EVERY JEEP IS DIFFERENT. but again you already know that since you had a tj on 38's, right? just cause you ran a set up half #%^ doesnt mean you should reccommend someone else should.
ΜΟΛΩΝ ΛΑΒΕ
post #22 of 99 Old 07-01-2010, 08:51 PM
jeepinmichguy_
this is the best yet, apex here could be the best driver in the world but as you know, is it really his driving on stock brakes he needs to worry about or all the other people on the road that cant drive around him? i know i have been in some crappy situations caused by other people not paying attention.
ΜΟΛΩΝ ΛΑΒΕ
post #23 of 99 Old 07-01-2010, 08:52 PM
chadsmeltzer
chadsmeltzer's Avatar
I run 35's with 3" suspension and 1.25" body lift. I daily drive it about 90 miles a day and it sucks, but it isn't as bad as I thought. I am also on stock brakes, and while I plan to upgrade them soon, they are also better then I thought.
I need to cut the rear fender slightly and thinking about a 1" spacer on top of my current lift. It's higher then I would like, but I don't have the time/tools to go tube fenders, nor do I really want to cut my body that much. I will just have to sacrifice uptravel for now.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #24 of 99 Old 07-01-2010, 09:10 PM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
will i have to trim the fenders or tub to fit the 35's?
post #25 of 99 Old 07-01-2010, 09:35 PM
Apex
Recon death squad
Apex's Avatar
It was already answered...depends on your lift and your bumpstops...
Apex is offline
post #26 of 99 Old 07-01-2010, 09:43 PM
Haik
supaJEEP
Haik's Avatar
for the time being till i can gather some more cash
I think you should reconsider. I hate bursting a bubble, but you're going to NEED to spend a lot of money to keep this DD on the road.
Haik
-SOLD- White Jeep Club Member #8675309
Rubicon Express 5.5" Long Arm Lift Kit - Advance Adapters SYE w/ Custom driveshaft
35" SuperSwamper Boggers - SMF rear bumper w/ swingout tire carrier
Cobra 75 WX ST - Firestick II 5' - PIAA 520 - PIAA 525 - 488 Gears - Detroit Locker
SMF front
bumper w/ bull bar - Warn 9500ti winch
Haik is offline
post #27 of 99 Old 07-01-2010, 09:55 PM
JeepnBlake
JeepnBlake's Avatar
Where's the link to the Green and Yellow pads at?
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #28 of 99 Old 07-02-2010, 05:02 AM
chadsmeltzer
With the same amount of lift, I will. It's only the inner fender though, you can't see it with the flares on.
Link to the yellow pads...
Discount Brakes - E35DP41255R
post #29 of 99 Old 07-02-2010, 06:34 AM
rideraa
didn't see it mentioned, a small piece of good news for you .. since you have a LJ your chance of vibes is diminished, you might be able to put off the sye and/or use less "T" case drop.
"CHEAP HEAP" TJ, 4.0, 32rh, 231, built D44's, 37s etc.
"George 4man" CJ7, 304, 727, D300, C/O rear w/ stretch, built D44's (4 now) on pane :).
rideraa is offline
post #30 of 99 Old 07-02-2010, 07:11 AM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
Great! ive bever heard that before about an lj, but i really want to elminate any body trimming what so ever
35 , lj , wrangler , regear , vanco , brakes , advice
anyone running 35's with 4:10s on a 2.5l? Unii YJ Wrangler Technical Forum 6 05-01-2010 06:12 PM
running on 35's... dwillz07 TJ Wrangler Technical Forum 9 03-21-2008 08:21 AM
running 35's dire TJ Wrangler Technical Forum 21 11-28-2006 01:50 PM
RE 4.5 no bbl and running 35's Red Rubycon TJ Wrangler Technical Forum 2 10-24-2004 12:30 PM
