Adding Power Steering to a TJ - Page 2 - JeepForum.com
post #16 of 23 Old 04-27-2009, 11:19 AM Thread Starter
BillyV65
BillyV65's Avatar
Just another quick question as I'm still working on this project:
Could someone with a '97 2.5 (and possibly 4.0) verify that the PS resevoir is located at the pump or is mounted in another location?
I've got the pump located and picking up the box, pump, lines and bracket today at a local boneyard and want to make sure before I get there that I will need the resevoir.
Thanks again!!!
BillyV65 is offline
post #17 of 23 Old 04-27-2009, 11:33 AM
Muratus
Muratus's Avatar
Hope this helps. My Reservoir is mounted off the radiator. But the pic blow shows the whole system.
Muratus is offline
post #18 of 23 Old 04-27-2009, 11:41 AM Thread Starter
BillyV65
BillyV65's Avatar
Thanks a ton!
Funny thing, is I own the FSM in PDF and didn't even think about looking at that for the layout. Always a brain fart
BillyV65 is offline
post #19 of 23 Old 04-27-2009, 02:43 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i have a spare PS pump if you want it, send me a PM and ill get you price for shipping, ill let it go cheap
RnEmOvr is offline
post #20 of 23 Old 04-27-2009, 09:59 PM Thread Starter
BillyV65
BillyV65's Avatar
Thanks alot bro, but I picked one up at a local boneyard this morning. If you had a line on the high pressure hose and the return hose that would be a home run for me (I'm mostly focused on the return hose as I can buy the high pressure hose).
I couldn't find any today as the junkyards had all cut them with no spares.
Anyone have any ideas???
I'm stalled until I can figure this out
Thanks again fellas
BillyV65 is offline
post #21 of 23 Old 04-28-2009, 02:41 AM
BigD97TJ
Right there with ya in no powersteering. I'm going to try and get everything from the junkyard too. interested to see what you do about ur houses.
BigD97TJ is offline
post #22 of 23 Old 04-28-2009, 04:04 AM
RnEmOvr
RnEmOvr's Avatar
i know you can buy both lines at advanced auto, but if you have a KOI they are alot cheaper
RnEmOvr is offline
post #23 of 23 Old 04-28-2009, 10:11 AM Thread Starter
BillyV65
BillyV65's Avatar
Ah, well I didn't know that. I was looking over their websites and and only saw the high pressure hose.
Since I have the metal portion of the low pressure hose still on the box, could I just route hose from that metal hose off the box to the resevoir? Now I just gotta bite the bullet and spend $75 on a hose
BillyV65 is offline
Adding power steering to a TJ 0psisucks TJ Wrangler Technical Forum 13 08-30-2009 09:32 AM
adding power steering? Foreveralout YJ Wrangler Technical Forum 14 12-06-2007 08:35 PM
Any good links re: adding power steering? drew2000 YJ Wrangler Technical Forum 5 10-29-2006 02:30 PM
Power steering pressure line/ power steering belt Ryanjeeper YJ Wrangler Technical Forum 4 11-10-2005 06:10 PM
Adding Power Steering to a 90YJ 4cyl spyon12 YJ Wrangler Technical Forum 2 08-21-2002 08:34 PM
