Adding Power Steering to a TJ - JeepForum.com
post #1 of 23 Old 02-25-2009, 08:24 PM Thread Starter
BillyV65
BillyV65's Avatar
Well, somehow I managed to pick up what seems like the only manual steering TJ. I also have about 25-35 degrees of play in the steering box and will have to replace it ASAP; I called a Jeep junkyard today and they had a few power steering boxes for TJs, but no manual steering boxes.
My question is how hard would it be to add power steering to my rig? I can get a PS box for $100 and I figure I can get the pump, pulley and lines for another $50-$100 and a manual box from NAPA is $239 w/$166 core.
Figure I can fix the loose steering and add PS and knock two birds out at once.
How easy is this to do?
BillyV65 is offline
post #2 of 23 Old 02-26-2009, 07:11 AM Thread Starter
BillyV65
BillyV65's Avatar
a bump for the morning crowd...heading to the salvage yard today
BillyV65 is offline
post #3 of 23 Old 02-26-2009, 07:32 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
I didn't have PS on my old YJ,but I've never heard of a TJ without it.
TheBoogieman is offline
post #4 of 23 Old 02-26-2009, 09:33 AM
LandoCommando
Can we see a pic of under your hood, I need to see it to believe it.
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline
post #5 of 23 Old 02-26-2009, 09:35 AM
TJMunky
TJMunky's Avatar
some one ganked your PSP (lol) did you check under the hood im pretty sure every single TJ came with powersteering. look for lines running to the gear box bro.
NIGHTCREW (RIP 01/28/09 - 07/22/09) #135
SILVER JEEP CLUB #120
TJMunky is offline
post #6 of 23 Old 02-26-2009, 09:38 AM
ca-rj
All TJ's had power steering.
Ryan
2005 Jeep Wrangler Unlimited Rubicon Sahara
OME 2.5" springs | Doetsch Tech DT3000 shocks | 285/75-16 Nitto Terra Grappler AT's | Yaesu FT-7800R | Cobra WX75st | Firestick Antenna | Alpine CDA-9883
ca-rj is offline
post #7 of 23 Old 02-26-2009, 09:42 AM
Chris98TJ
some tj's didnt come with power steering and some didnt come with a/c. go figure. i think if you would take all the p/s stuff off a donor vehicle it would go on your jeep. just make sure you get everything from the shaft to the pitman arm the pump the pulleys and a belt and the bracket that the pump boilts too. the pumps changed sometime cause they have some with the resivior built in and some without. i know my 98's is with so your 97 might be the same. just make sure you get it off the same engine size the bracket might be differnt from 4's to 6's.
98 tj sport Aussie locked front and rear 4.10's HPD30 8.8 super short sye cv shaft 4.5 lift johnny joint adj. control arms 36in TSL's gen right hi fenders header exhaust custom rockers Solid axle covers f/r the list goes on
Leading bullet sponge for JF Call of Duty crew
X BOX GT- CHRIS98TJ
Chris98TJ is offline
post #8 of 23 Old 02-26-2009, 10:01 AM
TheBoogieman
Distubed Jeepaholic
Ton's of jeeps don't have A/C,but I've never seen or heard of one without PS.Have you had one?
post #9 of 23 Old 02-26-2009, 10:12 AM
Chris98TJ
yes theres one for sale in the town next to mine. i had to go look at it to be sure but it didnt have anything just a manual box. you think napa would sell the part without it being an option on a vehicle?
X BOX GT- CHRIS98TJ
post #10 of 23 Old 02-26-2009, 01:04 PM
MuddyJeepZJ
MuddyJeepZJ's Avatar
A-1 CARDONE Part # 275000 {Reman.}
Manual Steering* Non-stock item--shipping delayed up to 2 business days
$207.89$150.00$357.89
At www.RockAuto.com
2004 Jeep Wrangler Rubicon
2003 Dodge Ram 3500
MuddyJeepZJ is offline
post #11 of 23 Old 02-26-2009, 01:42 PM
Giviner
Giviner's Avatar
At a glance (and this is using the ol' eyeball ruler) the bolt pattern for that manual box appears to be the same as for the PS box (no real reason why Jeep would make it different anyway I suppose). If you pull the box, lines, pump, and bracket from the donor vehicle you should be good to go. Then hit up Napa for a new serp. belt.
2003 TJ Sahara
2010 WK
Giviner is offline
post #12 of 23 Old 02-26-2009, 02:31 PM
BlueFlame
BlueFlame's Avatar
Yes, a LOT of base model TJs (SE) came with no power steering. Only in 97 I believe. Before they started 'value added' stuff, the base model was very base indeed. Even a rear seat was an option.
The quick order package that included power steering also included an am/fm radio!...
Made a CJ look fancy...
BillyV - get everything. Box, lines, pump, brackets, etc . ALSO take a Good look (take a pic and bring it with you) of your belt and pulleys setup. Get the belt and the tensioner etc - anything that's different than yours.
Then just bolt it all on. It's a no brainer.
BlueFlame is offline
post #13 of 23 Old 02-26-2009, 02:46 PM
TheBoogieman
Distubed Jeepaholic
Thank you grasshopper,now it is time for me to leave.I figured it was a 97' change over thing.Good info.
post #14 of 23 Old 02-26-2009, 06:41 PM Thread Starter
BillyV65
BillyV65's Avatar
Thanks alot for all of the info, guys! I would have just figured that P/S would have been standard equipment in '97, but seems it's not.
I figured I could pick up all the equipment from a donor vehicle, which is what I'm gonna do.
Thanks again!!
BillyV65 is offline
post #15 of 23 Old 02-26-2009, 07:13 PM
hscrugby
That's crazy. My dad's 97 was as base as he could get, (no radio even) only option he got was the bigger gas tank, and back seat.
And it didn't have the back seat, they actually ordered one for him.
But he has power steering.
(I know, cause it's leaking. and I need to get up there to give him a hand replacing it)
hscrugby is offline
Adding power steering to a TJ 0psisucks TJ Wrangler Technical Forum 13 08-30-2009 09:32 AM
adding power steering? Foreveralout YJ Wrangler Technical Forum 14 12-06-2007 08:35 PM
Any good links re: adding power steering? drew2000 YJ Wrangler Technical Forum 5 10-29-2006 02:30 PM
Power steering pressure line/ power steering belt Ryanjeeper YJ Wrangler Technical Forum 4 11-10-2005 06:10 PM
Adding Power Steering to a 90YJ 4cyl spyon12 YJ Wrangler Technical Forum 2 08-21-2002 08:34 PM
