Ac issue on 2000 tj - JeepForum.com
 1Likes
post #1 of 20 Old 05-30-2019, 02:28 PM Thread Starter
jeepercreeper92
Ac issue on 2000 tj
My ac just stopped blowing cold air and is only blowing hot air. It just stopped. What could it be? It has went from ice cold to hot in in a matter of 2 secs.
jeepercreeper92 is offline
post #2 of 20 Old 05-30-2019, 02:31 PM
LuthWJ77
LuthWJ77's Avatar
Leave it on see what the compressor is doing? Clutch engaging disengaging as it cycles? If it was a sudden stop I'd assume something is stopping compressor from coming on.
LuthWJ77 is offline
post #3 of 20 Old 05-30-2019, 02:44 PM
mukluk
mukluk's Avatar
Hot as is in ambient air temp or hot as in it feels like the heater is on?
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #4 of 20 Old 05-30-2019, 02:54 PM Thread Starter
jeepercreeper92
Like the heater is on
post #5 of 20 Old 05-30-2019, 03:13 PM Thread Starter
jeepercreeper92
I just checked. Its hot but not like when the heater is on
post #6 of 20 Old 05-30-2019, 03:38 PM
mukluk
mukluk's Avatar
x2 on checking the compressor then.
Check PDC fuse 21, fuse box fuse 11, swap the horn and AC relay, and make sure nothing is obviously wrong under the hood (leaks, frozen AC line, wiring/connectors).
2000 TJ SE
2005 LJ Rubicon
post #7 of 20 Old 05-31-2019, 05:21 PM Thread Starter
jeepercreeper92
I found the issue. The ac clutch is going bad. You can tap on the clutch and it will work for awhile. Anything i can do besides replacing the whole compressor?
post #8 of 20 Old 05-31-2019, 05:38 PM
2jhanna
I haven't on my jeep, but I've replaced just the clutch on other vehicles.
RockAuto has the cultch listed on their site, so must be doable.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #9 of 20 Old 06-01-2019, 07:19 AM Thread Starter
jeepercreeper92
I called the local jeep dealer and was told that the compressor and clutch are sold as one unit
post #10 of 20 Old 06-01-2019, 10:49 AM
2jhanna
I'm sure that's their policy. Go with the dealer if that's what you want.
Did you visit the RockAuto site like I listed above.
You asked for info and it was provided.
jhanna
denton county, tx
2jhanna is offline
post #11 of 20 Old 06-01-2019, 12:43 PM
JEK3
JEK3's Avatar
Aftermarket frequently does things differently than factory. Personally, I'd give the Rockauto clutch a try, as replacing the compressor is a lot more expensive. You can't do the compressor yourself, since it involves vacuuming out and replacing the refrigerant, replacing the drier, and making sure the correct amount of oil is replaced. Doing just the clutch can be done in your driveway with simple hand tools.
2jhanna likes this.
JEK3 is offline
post #12 of 20 Old 06-01-2019, 12:52 PM
2jhanna
My point exactly, couldn't have said it better !
jhanna
denton county, tx
2jhanna is offline
post #13 of 20 Old 06-01-2019, 02:06 PM
jtec
2014 JK Wrangler
Hard to believe the dealer made that mistake...
See your local parts dealer fpr parts, no need for a OEM component, be sure to ck air gap.
jtec is offline
post #14 of 20 Old 06-02-2019, 03:15 PM Thread Starter
jeepercreeper92
Went to the local parts store and was told that they dont sell just the clutch.
post #15 of 20 Old 06-02-2019, 03:31 PM
JEK3
JEK3's Avatar
I've had great experience with Rockauto, as listed above. Local parts stores can be funny on what parts they actually sell.
JEK3 is offline
