98 wrangler window crank removal? - JeepForum.com
post #1 of 3 Old 03-25-2010, 11:55 AM Thread Starter
Uee
My jeep's driver side door no longer opens from the outside, only the inside. I started the process of getting the inside plastic part of the door off and seem to have gotten stuck at the windo crack. How do I get this crank off? I haven't been able to find any information discriptive enough on the web yet. Any help or tips for the process out there?
Uee is offline
post #2 of 3 Old 03-25-2010, 12:30 PM Thread Starter
Uee
ok never mind on that i got the crank removed, now it looks like the problem lies with the outside door handle but on the inside of the door. Does anyone know how to gain access to that area?
Uee is offline
post #3 of 3 Old 03-25-2010, 03:32 PM
BlueFlame
BlueFlame's Avatar
After you removed the door panels, it should be completely accessible. Roll the window up?
https://www.jeepforum.com/gallery/sho...8&ppuser=71619
BlueFlame is offline
window crank door
Removing Window Crank Emtee TJ Wrangler Technical Forum 3 07-18-2007 05:39 PM
Window Crank TWrangler TJ Wrangler Technical Forum 3 12-29-2006 08:51 PM
window crank brundz YJ Wrangler Technical Forum 1 09-03-2006 05:59 AM
Window Crank Removal!! DaJeepMan9 YJ Wrangler Technical Forum 4 02-06-2005 08:04 AM
Window Crank removal 2002 TJ Dragonmaster TJ Wrangler Technical Forum 3 02-22-2004 05:46 PM
