97 Jeep TJ, can not find an air scoop??? Anyone know where to get one? - JeepForum.com
post #1 of 48 Old 10-22-2008, 07:32 AM Thread Starter
toddgaw
I have a 1997 Jeep Wrangler TJ and have looked high and low for an air scoop. The unit would measure approx 33" long. All I can find out there are for 98's and up. Outland (model 5306) made one but it appears that they have been discontinued. Have tried 12 different websites, including JC Whitney and eBay, to no avail. My buddy has one on a 98 and makes a big difference in the cabin airflow.
Does anyone know who might have this item to fit my jeep or know of anyone that will custom make it in the Atlanta area??? THANKS!!!
toddgaw is offline
post #2 of 48 Old 10-22-2008, 07:35 AM
TJRubicon06
TJRubicon06's Avatar
http://quadratec.com/
Search for bushwacker
06 TJ Rubicon
Black Jeep Club member #95
1-20-13
Getting
TJRubicon06 is offline
post #3 of 48 Old 10-22-2008, 03:50 PM
Maxxram
Maxxram's Avatar
I have been looking for the same. I checked Quadratec's site but they only have them listed for 98 and up, no 97.
Maxxram is offline
post #4 of 48 Old 10-22-2008, 04:03 PM
DBLJ
DBLJ's Avatar
Its because of the the cowl. We have more sections that have the slots. Every other TJ has just one section. If you really want a scoop you can grab a cowl from a different year TJ and throw that on.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #5 of 48 Old 10-22-2008, 04:05 PM
cmc1
I have a 97 also.they used to make one for just them but not anymore.1997 were alone in the vent on the cowl.the 1998s and up use a smaller opening.
cmc1 is offline
post #6 of 48 Old 10-22-2008, 05:14 PM
dbbd1
dbbd1's Avatar
Does it really make that much of a difference? Not trying to be a [email protected], really a serious question.
dbbd1 is offline
post #7 of 48 Old 10-22-2008, 07:28 PM
Soundguy101
Guest
I would like to know too?
Soundguy101 is offline
post #8 of 48 Old 10-22-2008, 07:29 PM
cmc1
No. 97s had ventilation problems from the factory.why they redesigned the 1998 and newer models.
cmc1 is offline
post #9 of 48 Old 10-22-2008, 07:31 PM
Kenbo-Slice
Kenbo-Slice's Avatar
I have never been in a Jeep with the scoop, but I am curious if it helps getting more heat in the winter.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #10 of 48 Old 10-25-2008, 12:08 PM
Jeepkid09
so no one knows?
Jeepkid09 is offline
post #11 of 48 Old 10-25-2008, 12:32 PM
herTJ_hiswork
Guest
i just fabed up one for bout 10 bucks from a lowes heater vent cowl....body filler and some truck bed coating...looks awesome and you would never know it was home made
herTJ_hiswork is offline
post #12 of 48 Old 10-25-2008, 01:29 PM
Jonny Jeep
Jonny Jeep's Avatar
I've had water leak inside the cab from the solid section of the black plastic under the vents. It managed to seep through the plastic/metal join and make it's way to the corner of the plastic on the underside. From there it was directly above the air intake where it leaked down into the passenger footwell. Maybe that's why it changed.
Jonny Jeep is offline
post #13 of 48 Old 12-18-2008, 08:51 PM Thread Starter
toddgaw
Hey" herTJ hiswork" Do you by chance have a phot of the one you made? Here is a link to one of the Outland Model 5306's for sale. However, I can't seem to get an answer as to whether they actually have it in stock. http://www.jeepparts4x4.com/product_...oducts_id=1623
toddgaw is offline
post #14 of 48 Old 12-18-2008, 08:56 PM
Nonya
Something else is wrong if you can't get enough heat.Blocked heater core etc.
Nonya is offline
post #15 of 48 Old 12-18-2008, 09:23 PM
RYANSTULC
RYANSTULC's Avatar
Do they work? Yes, they are an excellent debris trapping device. Leaves, litter, snow,,,pretty much anything in the air will quickly jamb up the scoop.
The PO of my Jeep installed one, and I promptly removed it. No problems.
If you actually get a scoop, make sure the open end is towards the windshield,,,,not the front bumper. (at least that's the proper way of mounting them on 98's and newer)
RYANSTULC is offline
air scoop DGoodman111 YJ Wrangler Technical Forum 34 10-31-2013 02:27 PM
Hood scoop vs AC Scoop vs RunCool (( what are you running on your hood? )) gamer0 YJ Wrangler Technical Forum 7 04-12-2009 07:01 PM
A/C Air Scoop? 90yjkrawler YJ Wrangler Technical Forum 3 08-04-2006 07:35 AM
Scoop adp5025 TJ Wrangler Technical Forum 0 09-28-2005 03:33 PM
where to find hood vent scoop mudmann105 YJ Wrangler Technical Forum 4 02-15-2004 06:56 AM
