8.8 Swap, the Cliffs-Notes - Page 10 - JeepForum.com
 5Likes
post #136 of 145 Old 05-26-2016, 03:05 PM
Deacon
Deacon's Avatar
Oh man I've had so many of those nylon lock nuts rattle off and never had bolt threads marred by the intentionally misshapen metal ones.
Deacon is offline
post #137 of 145 Old 05-27-2016, 05:55 AM
26679cj5
26679cj5's Avatar
If you drill out the knuckle (or factory trackbar mount), do yourself and your wrists a favor and pony up for a tapered reamer bit. A little cutting oil and they'll go through the thick stuff easily.
26679cj5 is offline
post #138 of 145 Old 05-27-2016, 08:33 AM
biffgnar
biffgnar's Avatar
A quality reamer does help this a lot, although $$.
biffgnar is offline
post #139 of 145 Old 05-27-2016, 10:00 AM
Deacon
Deacon's Avatar
It may be dumb, but I always always worried I'd over-drill with the reamer as well. It seems a lot easier to get a quality drill bit, some drilling oil, and get a nice straight hole the whole way through, and then drop in an insert.
Deacon is offline
post #140 of 145 Old 05-27-2016, 10:11 AM
grininmonkey
grininmonkey's Avatar
So.. this may be dumb as well (sorry)... But if you use the reamer method, your result is going to be a non tapper whole if you widen the top which is the tapered end... No? You still need the insert ?
grininmonkey is offline
post #141 of 145 Old 05-27-2016, 12:21 PM
xxdabroxx
xxdabroxx's Avatar
You can get a reamer that leaves you with a non tapered hole the diameter of your choosing, then you could use the tapered sleeve. I also believe you can get a reamer with the proper taper, but I would think you would have to go with an oversized tie rod at that point. Not sure though, just guessing.
xxdabroxx is offline
post #142 of 145 Old 05-27-2016, 04:20 PM
26679cj5
26679cj5's Avatar
Yes, it drills the hole out at a taper until the bit goes in deep enoguh, then it straightens out to a normal hole. You put an insert in at that point.
Frame swap/body reconditioning/buildup thread:
26679cj5 is offline
post #143 of 145 Old 05-27-2016, 05:43 PM
Deacon
Deacon's Avatar
Well, there are two relevant kinds of reamers. One is a fancier version of a drill bit specifically designed for making existing holes bigger. There's also a conical reamer, where it leaves a hole of a particular size and slope depending on the shape of it and how far you go with it.
I did it with just a quality drill bit, but if you have access to a nice straight reamer, then that would be a great choice.
Deacon is offline
post #144 of 145 Old 05-27-2016, 06:03 PM
biffgnar
biffgnar's Avatar
There are people in the world who have use for the quality reamers on a repeat basis. You can buy one, use it yourself and then, if you ask nicely, they might have appetite to buy them off of you for close to the high dollar price they cost.
biffgnar is offline
post #145 of 145 Old 05-27-2016, 06:09 PM
xxdabroxx
xxdabroxx's Avatar
I've heard you can pick them up fairly cheap on ebay too.
