8.8 + axle length and backspacing ?? - JeepForum.com
post #1 of 12 Old 10-26-2014, 12:02 PM Thread Starter
mikedff23
I ordered an 8.8 from ECGS, I know the 8.8 is like a little shorter than the dana35. Will I need wheel spacers or will I be okay? My rims already have. 4.25 backspacing on them
mikedff23 is offline
post #2 of 12 Old 10-26-2014, 12:21 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2020 J-Series Truck
How wide are your tires and what brand are they?
Do you have an adjustable rear track bar?
Wheelin98TJ is offline
post #3 of 12 Old 10-26-2014, 12:26 PM Thread Starter
mikedff23
16x8 rim with 4.25 backspacing Tire is 285x75x16. Negative on the adjustable traction bar. Necessary?
post #4 of 12 Old 10-26-2014, 12:30 PM Thread Starter
mikedff23
I lied. Forgot I ordered currie adjustable bars with the rear !
post #5 of 12 Old 10-26-2014, 12:50 PM
Wheelin98TJ
JEEP FREAK
2020 J-Series Truck
As long as you get the axle perfectly centered with your adjustable rear track bar, I think you will be ok.
Its going to be close though.
Might have to trim the upper coil perches a little. And if you do need to do this, after trimming the coil perches, check to see if the tire rubs on the frame after it passes the area where it used to rub on the coil perch.
post #6 of 12 Old 10-27-2014, 08:04 AM
deputyjason
I've just strated researching rear ends and was impressed at the comparative savings from ECGS on an 8.8. Wouldn't a pair of 1.25in spydertrax spacers solve any issues with the axle being shorter?
deputyjason is offline
post #7 of 12 Old 10-27-2014, 08:16 AM
Dueces
Dueces's Avatar
Did you order the axle with c clip eliminators and chromoly axles, i think that makes the axles a little wider.
Dueces is offline
post #8 of 12 Old 10-27-2014, 08:48 AM
UTWeezul
This would solve your issues
98 TJ
Armored up and locked up
38s with Racelines
103" wheelbase
UTWeezul is offline
post #9 of 12 Old 10-27-2014, 08:49 AM
UTWeezul
I believe that kit adds an inch per side.
98 TJ
38s with Racelines
103" wheelbase
UTWeezul is offline
post #10 of 12 Old 10-27-2014, 09:46 AM
lindel
lindel's Avatar
Per the FAQ at ECGS, "Ford 8.8 WMS is 59 5/8 - Stock TJ is 60.5", just under an inch narrower, or a half inch on either side. 1.25" spacers would work, and in the overall scheme of things wouldn't look bad. I would do a test fit with the wheels before putting spacers on it.
The wheels I'll be using (I have TJ Canyon wheels at the moment) will have 3.5" of back spacing, so I shouldn't have any issues. I hope to be ordering my 8.8 in a week or so.
Lindel
1999 Flame Red Sport, with some mods...
1999 Gunmetal Sport, waiting for some mods...
lindel is offline
post #11 of 12 Old 10-27-2014, 10:54 AM
Grunt77
I had to trim my spring perches slightly to clear the wheel.
"Never underestimate the predictibility of stupidity"
RIP SSG Brad King. KIA April 2, 2007
Grunt77 is offline
post #12 of 12 Old 10-27-2014, 01:42 PM
deputyjason
I apologize. I thought it was an 1.25 in each side shorter.
