5 speed vs 6 speed trans for a 2005 tj - JeepForum.com
 3Likes
post #1 of 26 Old 02-09-2014, 01:06 PM Thread Starter
greenorangejeep
should i pay the extra money for a 6 speed t
rans? is it worth it for my 2005 tj?
greenorangejeep is offline
post #2 of 26 Old 02-09-2014, 02:30 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Stick with the auto.That's no easy swap.
TheBoogieman is offline
post #3 of 26 Old 02-09-2014, 02:37 PM
Rubiman805
I have an 04 Rubi that had a 5spd and now it has an AW4. go for an automatic.
TJosh02 likes this.
Rubiman805 is offline
post #4 of 26 Old 02-09-2014, 03:38 PM Thread Starter
greenorangejeep
i got a auto i want it 2 b a stick shift y is it hard 2 do? y stay auto?
post #5 of 26 Old 02-09-2014, 04:24 PM
murfman1967
Auto transmissions are for people who cant drive lol Honestly I think a TJ/YJ/CJ feels so much sportier on the road with a manual trans, and i like the extra control I have off road as long as you have decent gearing. My TJ is the first stick off road vehicle I ever owned, and I dont think I will ever have another Auto trans in a trail rig. That said, stick with the 5 speed, the 6 speed has bad ratio splits, honestly I'd go for an AX-15 over the 3500/3550. Parts are still available and the 3500/3550 are orphans and getting hard to find parts for. The NV 4500 is a big heavy pig but it is another option if you don't mind modding the floor pan/skid plate to get it in.
murfman1967 is offline
post #6 of 26 Old 02-09-2014, 04:43 PM Thread Starter
greenorangejeep
so the six speed does not work that good? and the ax-15 r pretty cheap anyone know y it is hard 2 change from auto 2 manual?
post #7 of 26 Old 02-09-2014, 04:45 PM
TheBoogieman
The way I understand it,the 05'-06' 42rle auto can't be easily swapped without a lot of work.I could be wtong,but I doubt it.
https://www.jeepforum.com/forum/f9/05...anual-1772569/
post #8 of 26 Old 02-09-2014, 04:48 PM
TheBoogieman
Anyone who goes off road would disagree with you.An auto has much more control.
post #9 of 26 Old 02-09-2014, 05:00 PM
LilyBayXJ
LilyBayXJ's Avatar
If we're talking strictly 5-spd manual vs. 6-spd manual (which is how I interpreted your thread subject), there are pros in cons to each.
The 5-speeds found in TJ's (with the exception of the AX5), are the AX-15 and NV3550, which seem to be bulletproof.
The 6-speeds found in '05-up Wranglers is the MB-built NSG370. This transmission has been know for having numerous problems.
However, having owned and driven 5-spd and 6-spd TJ's both for extended periods of time, I can say I definitely prefer the 6-spd. While the 1st gear ratio is stupid low for daily driving, 2nd gear is also low enough that you can easily start with it. Plus, I find the low 1st gear optimal for wheeling.
Also, I never cared for the large gap between 4th and 5th gear on the 5-spds. On the 6-spd, all the gear ratios seem to be an optimal to for smoother upshifts and more precise power choices for downshifts.
So for reliability, the 5-spds are undoubtedly better. But for drive-ability, I greatly prefer the 6-spd.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #10 of 26 Old 02-09-2014, 05:13 PM Thread Starter
greenorangejeep
so the NV3550 is a really good trans?
post #11 of 26 Old 02-09-2014, 05:41 PM
LilyBayXJ
LilyBayXJ's Avatar
Reliability-wise, yes it's a very solid transmission.
post #12 of 26 Old 02-09-2014, 06:44 PM
Snowplow
Snowplow's Avatar
I have a NV 3550 And it was badly rebuilt, only took 2 months to start making noise. but i will say its a tough trans even with the internal damage and all the noise it still works, it just wont die.
Snowplow is offline
post #13 of 26 Old 02-09-2014, 06:47 PM
LilyBayXJ
LilyBayXJ's Avatar
It sounds like that may be the fault of whoever rebuilt it. But generally that seems to be the case, it takes quite a bit to kill one.
post #14 of 26 Old 02-09-2014, 06:52 PM
commander184
I grind a lot of gears with my 6 speed ....ax15 is nice.. I do like my 4l60 in my s10 I have 1st 2nd and drive so I have the same control over gearing but it has to rev much higher do to an auto being a slush box
'95 SaS s10 4 door blazer (one owner) dana 44's 36's, '05 rubicon 35's 4.5 rubicon express and 9.5ti
commander184 is offline
post #15 of 26 Old 02-09-2014, 09:52 PM
trickydick
I have the six speed in my 05 and I thinks its great, the only gear I've ever ground was going into first with in the first minute of starting it on a very cold morning, after one minute of driving it never happens and it's only happened just once.
trickydick is offline
