5.0 engine swap pictures - Page 81 - JeepForum.com
View Poll Results: What do you think?
Like it. 444 41.93%
Awesome wish mine had that. 458 43.25%
You just ruined a perfectly good jeep 69 6.52%
Why would you replace a 2.5 with a 5.0. 2.5 are the best 88 8.31%
Voters: 1059. You may not vote on this poll
 3Likes
post #1201 of 1211 Old 12-11-2017, 07:24 PM
fordjeep89
I just joined forum did a 5.0 swap in my 97 about a year ago wish I would have seen this tread lot of great info!!! several questions but ill try to be short mine has ran rich since day one did you just use you jeep fuel return line and jeep pump or modify?? i also went with the e 303 cam kinda wishing i would have left stock explorer cam in now how do you like yours
fordjeep89 is offline
post #1202 of 1211 Old 12-11-2017, 07:30 PM
fordjeep89
new to forum just found this thread did a 5.0 swap in my 97 about a year ago wish i would have seen this tons of great info!!!! few quick questions mine has ran rich since day one did you use jeep fuel pump and also did you use jeep return line??? i also used the e303 cam have thought since i might have been better off with the factory explorer cam how do you like yours???
post #1203 of 1211 Old 12-11-2017, 10:45 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
TJ's don't use a fuel return line...
Knuckelhead is offline
post #1204 of 1211 Old 12-12-2017, 10:07 PM Thread Starter
472cid
472cid's Avatar
Early explorers used a return. You can tap into the filler neck and add a return. Will help with running rich because the jeep uses higher fuel pressure
Knuckelhead likes this.
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline
post #1205 of 1211 Old 12-13-2017, 02:35 AM
fordjeep89
All I remember is hooking up two lines gonna check into that
post #1206 of 1211 Old 12-13-2017, 05:22 PM
Knuckelhead
R.I.P. Knuckelhead
Post back as to what you find?...
post #1207 of 1211 Old 01-27-2018, 05:03 PM
fordjeep89
I had 2 lines running down frame tail from my fuel tank on is pressure assumed the other to be a return? Also where did you guys mount the ford ecm I can't see pictures for some reason
post #1208 of 1211 Old 02-01-2018, 07:10 PM
Jim1611
Jim1611's Avatar
Sounds like you're dealing with a later model but for the CJ owners I mounted my ecm in the same location as the one that it came out with. The bracket is almost a perfect fit.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #1209 of 1211 Old 08-04-2018, 08:04 PM
BDC1
I have been planning on a 5.0 swap in my yj for about a year. I had actually lost the love for the whole idea deciding that the 2.5/ ax5 was great for everything 45 mph and under. I started thinking about it again and found this thread. I am all in at this point. Hands down the best information thread on the subject I have ever found. Thank you to Amos for allowing every to share their own for the good of the whole. I have a complete maf roller 302 in a 1994 van that runs and is complete. $100 bill. I also have my old wagoneer. It has a 20k mile tbi 350 mated to a 5.61 nv4500 mated to a 4.3 atlas 2 speed that is practically brand new. The 350 is for sale. I am torn between the nv4500 and an ax15. I will probably use the atlas because it's here and paid for. This project will take place this winter. I have lots of ideas I want to bounce of you all. Today I just wanted to announce my presence.
BDC1 is offline
post #1210 of 1211 Old 08-04-2018, 08:37 PM Thread Starter
472cid
472cid's Avatar
Awesome, glad to hear. I am happy to hear people getting use out of the info. Wish photo bucket and ford fuel injection links didnt get fubared
472cid is offline
post #1211 of 1211 Old 08-05-2018, 08:20 AM
BDC1
There is still quite a few good pictures on here Amos.
My first decision to make is critical to the way a I look at the entire end result. Ax15 or nv4500.
I currently own a good rebuilt nv4500. It came out of a 95 chevy 2500.
Ax15's are affordable but I do not own one currently.
This jeep will remain nice so floor cuts matter to me.
I would appreciate some input here. All opinions are welcome.
BDC1 is offline
5.0 , 5.0 liter , 5.0l , engine swap , ford , motor swap , v8
YJ to CJ dash swap write up with pictures rrisher YJ Wrangler Technical Forum 172 05-17-2019 12:41 AM
Engine swap pictures 5.7YJ YJ Wrangler Technical Forum 22 08-26-2012 05:05 PM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
My roll bar swap with pictures YJames90 YJ Wrangler Technical Forum 6 02-18-2008 05:18 PM
4.0L Swap Pictures Inside. ID89YJ YJ Wrangler Technical Forum 3 01-29-2007 06:58 PM
