4wd shifter - JeepForum.com
post #1 of 5 Old 08-23-2004, 09:07 PM Thread Starter
dshabe
2010 JK Wrangler
4wd shifter
I just bought my Jeep about a month ago and I have noticed that the 4-wheel shifter has a tendancy to slide from 2wd toward 4hi when Driving around on pavement. Does anyone know if this is common or is this an indicator that something is loose or out of adjustment?
thanks
98 Wrangler
1" BL
1" MML
2" BDS Lift
BFG 32X11.5 AT
dshabe is offline
post #2 of 5 Old 08-23-2004, 09:10 PM
GAjeepTJ
Guest
does the transfer case actually engage into 4wd or does the shifter just move up a little? if it acutall moves up and engages the tranfer case, then yes, something is either too tight or too loose and needs fixing.
GAjeepTJ is offline
post #3 of 5 Old 08-24-2004, 07:56 AM Thread Starter
dshabe
2010 JK Wrangler
I don't believe that the transfer case is engaging. I'll have to look into into it more.
Maybe my jeep is just trying to tell me to get off the pavement and use the 4wd
98 Wrangler
1" BL
1" MML
2" BDS Lift
BFG 32X11.5 AT
dshabe is offline
post #4 of 5 Old 08-24-2004, 08:39 AM
unrefined
unrefined's Avatar
Not trying to steal the thread but I had a related problem this weekend while wheeling around. When trying to shift back into 4hi from 4lo the shifter didnt want to move. Had to manhandle it a bit to get into 4hi. Jeep was in neutral at a stand still so I'm a bit confused. Any input would be greatly appreciated.
Air Force Jeep Club Member #10
unrefined is offline
post #5 of 5 Old 08-24-2004, 10:18 AM
Jasonoff
Jasonoff's Avatar
I had the reverse problem. Going over bumps in 4hi it would come out and knock like a madman. I put my jeep in yesterday for the rear main seal and this http://www.4x4xplor.com/T-CaseTSB.html
I'll let you know how it works out.
2017 Grand Cherokee Trailhawk (Tow Pig)
2010 C63 AMG Race Car (Track Pig)
Jasonoff is offline
Shifter-Shifter, get your Shifter. CoolContractor TJ Wrangler Technical Forum 19 10-28-2009 07:33 PM
Column Shifter to Floor Shifter covejeepsxj YJ Wrangler Technical Forum 8 04-03-2008 03:28 PM
B&M shifter in a YJ ?????? loborojo338 YJ Wrangler Technical Forum 7 10-18-2007 04:46 PM
column shifter to floor shifter conversion jeepwrnglr92 YJ Wrangler Technical Forum 3 07-03-2007 11:51 AM
Cherokee shifter acting as a Short throw shifter?? skyjacked94xj TJ Wrangler Technical Forum 7 02-03-2007 12:42 PM
