42rle Transmission Getting Hot - JeepForum.com
post #1 of 12 Old 06-26-2013, 09:02 AM Thread Starter
xndrxw
(42rle)So a week ago I noticed my transmission was taking longer to shift from first to second and back down. Once fluid seems to warm up this problem disappears. I have a temperature gauge on my transmission and it seems to be getting hotter than it should. Stop and go traffic two days ago it read 240 for about 5 minutes. I have replaced the filter as well as the pan. I am running the pml deep pan, derales inline filter as well as derales electric fan transmission cooler. I considered by passing the factory transmission cooler to see if that could be the issue but have not had a chance to do so yet and I would like to see if anyone has a suggestion. I have searched online for more information but could not find anything that was similar to my issue. Any help would be great.
http://www.expeditionnola.com/
xndrxw is offline
post #2 of 12 Old 06-26-2013, 10:10 AM
JBTJ
JBTJ's Avatar
Not that mine gets that hot, but I still replace ALL the fluid in the system once a year. Heat kills ATF.
JBTJ is offline
post #3 of 12 Old 06-26-2013, 11:28 AM Thread Starter
xndrxw
I replaced the fluid in the pan as well as the filter. I replace one quart of fluid as well as the inline filter every other time I change my oil. When I dropped my pan to replace the filter 2 weeks ago the fluid was still a nice red color not brown like it was being burnt.
xndrxw is offline
post #4 of 12 Old 06-26-2013, 11:55 AM
JBTJ
JBTJ's Avatar
Not sure about the shift problem as I have the 32RH, but hitting 240 in stop and go traffic with the AC on for a few minutes is not unheard of.
JBTJ is offline
post #5 of 12 Old 06-26-2013, 12:01 PM
jeepmutiny
1983 CJ7
You could put some ATF friction modifying fluid in and it helps lessen slippage. There are formulas for GM, Ford and Dodge. I know many mechanics that swear by it.....Jon
jeepmutiny is offline
post #6 of 12 Old 06-26-2013, 12:25 PM Thread Starter
xndrxw
Like the Lucas oil stuff or should I order some of the Lubeguard?
xndrxw is offline
post #7 of 12 Old 06-26-2013, 11:52 PM
2003RubiBlue
I wouldn't add anything to the transmission fluid. Always remember the mechanics that swear by it are also the mechanics getting paid when it blows up. My 2003 Rubi will get pretty hot in stop and go traffic and I have a temp gauge on mine, but I have never seen 240, I have seen 210 a few times but these were extreme, like July on the highway going on vacation stuck in traffic with the AC on. I have bypassed the factory cooler now, since I installed a larger cooler in the grille, but I have run it both ways and did not notice much of a temperature difference with the factory cooler in the circuit. How hot has it been on New Orleans lately. Maybe its just a few isolated instances, I mean like I said sometimes in traffic with the AC on the temp starts to climb because there is not enough airflow, sometimes I kill the AC and roll the windows down. Once i'm moving again everything cools down pretty quickly.
Brian
Will work for Jeep parts...
2003RubiBlue is offline
post #8 of 12 Old 06-27-2013, 09:26 AM Thread Starter
xndrxw
Brian
It has been in the 90s here lately. I have been driving with no AC on to see if it makes a difference and so far no change. This is the first summer with my new tires. Not sure how much of a difference that would make though. I went from 31s to 35s. Regearing it in the next month to 4.88 also.
xndrxw is offline
post #9 of 12 Old 06-27-2013, 10:34 AM
77351wcj5
The factory cooler is actually a pretty efficient cooler. Even though it is mounted in the cold side of your radiator, it also functions as a warmer-upper in the winter. You may have an indicator of future trans problems, could be low pressure or a slipping converter, but it sounds like the trans is trying to warn you.
77351wcj5 is offline
post #10 of 12 Old 06-27-2013, 11:23 AM
JBTJ
JBTJ's Avatar
Damn sure wouldn't want it mounted on the warm side of my radiator.
JBTJ is offline
post #11 of 12 Old 06-27-2013, 11:35 AM Thread Starter
xndrxw
I guess I will take it into a shop and have it looked at. Just have to find a shop that will not try to rip me off.
xndrxw is offline
post #12 of 12 Old 06-27-2013, 12:02 PM
boilerup1998
boilerup1998's Avatar
How many miles on it? What are your typical driving habits? Is it offroad much or pulling a trailer? Wasn't able to view your profile, so I don't know what kind of set up you're running...
boilerup1998 is offline
