42rle tranny cooler lines - JeepForum.com
post #1 of 5 Old 09-09-2011, 07:18 AM Thread Starter
pwmac
Please ID the in and out lines at the tranny or the rad.
Hard to believe my search did not find the answer. Lots of reading.
Thanks, PaulW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #2 of 5 Old 09-09-2011, 07:44 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
upper line is out to cooler, lower line is in from cooler. trace them to the radiator and you'll know which one to cut for an aux cooler.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 5 Old 09-09-2011, 08:06 AM
timberwolf0122
timberwolf0122's Avatar
2020 J-Series Truck
The way I id' them when I put the remote filter in was to disconnect them from the radiator and tie a garbage sack round both of them, then I quickly fired up the engine, shifted into and out of neutral and shut the engine down. The bag with all the fluid in it was the send line... Simple, you'll need to top up the tranny fluid anyway when putting in a radiator, this way you just need to add about a pint more.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #4 of 5 Old 09-09-2011, 11:59 AM Thread Starter
pwmac
42rle ??
Second question
Is there a port on the 42RLE for a gauge sender or do I need to use the cooler line or a weld on bung in the pan. All my other off road rigs have a pan bung, but it sure is a lot of effort.
Thanks, PaulW
pwmac
Durango, CO
pwmac is offline
post #5 of 5 Old 09-09-2011, 12:08 PM
timberwolf0122
2020 J-Series Truck
Not that I know of... But a quick googling turned up this, you can splice it into the rubber transition line.
http://cgi.ebay.com/ebaymotors/1-1-4...ht_2410wt_1193
Trans Cooler for the 42RLE LJameson TJ Wrangler Technical Forum 14 03-17-2013 08:03 AM
04 Auto - 42RLE - Transmission Cooler UnsanePyro TJ Wrangler Technical Forum 10 10-18-2010 06:29 PM
42rle tranny cooler install help. ryan2022 TJ Wrangler Technical Forum 2 12-26-2009 02:41 PM
42rle cooler line fun Kinless TJ Wrangler Technical Forum 0 07-13-2009 10:19 PM
42rle shift kit and cooler? Reelm n Rubi TJ Wrangler Technical Forum 1 06-26-2005 11:52 PM
