42RLE slow to go in gear when Hot - JeepForum.com
post #1 of 4 Old 07-23-2018, 05:15 PM Thread Starter
jjstaus
jjstaus's Avatar
When close to 100 degree days in Texas My TJ doesn't go directly into drive or reverse, but chatters like a slipping clutch. once in gear it doesn't slip, drives great. Again, only when very hot - I have already installed a nice DeRale cooler and the radiator is only a year old. any suggestions besides replacement?
forgot to mention I bought the TJ 10k miles ago with freshly rebuilt Trans. Chasis has 120K miles
jjstaus is offline
post #2 of 4 Old 07-23-2018, 05:26 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
How many miles on the tranny, Joe? I assume you have checked your fluid level, but you can safely add 1 quart of fluid beyond full. That may help a bit.
Jeff
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #3 of 4 Old 07-23-2018, 05:33 PM Thread Starter
jjstaus
jjstaus's Avatar
10 k miles on a rebuilt trans
Body has 120k mi but I am sure the trans was newly rebuilt when I bought it 10k ago.
jjstaus is offline
post #4 of 4 Old 07-23-2018, 07:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Ok but still check the ATF level. Engine running, shift through all the gears a couple times, make sure the engine is warmed, then check the ATF level while the engine is running. If it needs ATF be sure to only add ATF+4.
Jerry Bransford is offline
42rle , tj
