42rle or 4.0L causing vibes on stock drivetrain? - JeepForum.com
post #1 of 13 Old 08-06-2010, 11:13 AM Thread Starter
LJinNOLA
I'm not so much looking for a cure (yet), but rather trying to determine if this is normal.
I have an 04 LJ and I get some slight vibes/hum when I'm in OD, at about 1600+/- rpm and 50 +/- mph.
I know that the 42rle and 3.73s (on 30x9.5) leaves something to be desired, but is the engine lugging causing these vibes or the transmission. I get it almost everyday driving up a long incline at 50mph, but if I turn off OD rpms jump, vibes go away.
Anyone else have this? Should I be concerned? and if yes, what to do?
I have no lift.
2004 LJ. OME 933/942 JKS BL, Brown Dog MML. Homemade Trunk, Snorkel, Lined Tub.
LJinNOLA is offline
post #2 of 13 Old 08-06-2010, 11:15 AM
jimkonow
jimkonow's Avatar
1994 ZJ
hmm....have you checked the mounts?
*edit*
motor and transmission mounts
Originally Posted by Xerxes View Post
I need $$$$$$$ for O|||||||O
jimkonow is offline
post #3 of 13 Old 08-06-2010, 11:15 AM
2006_Sport
2006_Sport's Avatar
Not a vibe, but merely the sound of the engine not being in it's power band and the stock t case skid is drumming the noise and making it louder. It's normal and I've had it since I bought my jeep then lifted it and nothing has happened.
I wouldn't worry about it.
2006_Sport is offline
post #4 of 13 Old 08-06-2010, 11:25 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
its "supposed" to do that. bottom line is the 42RLE should have never been put behind a 4.0L. the engine is always out of the powerband, stock ratios are almost 1 whole point too high. 4.56s with 31s would be more reasonable with this tranny.
https://www.jeepforum.com/forum/f9/al...s-here-990762/
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 13 Old 08-06-2010, 11:26 AM
Imped
Imped's Avatar
This has actually been researched. It was discovered that the stock t-case skid allows the frequency at that certain RPM range. It's not hurting anything but I bet that would be annoying.
OlllllllO
IndyORV
Imped is offline
post #6 of 13 Old 08-06-2010, 11:27 AM
otisdog
2008 WK
I keep my OD turned off 90% of the time. Only use it at 60 mph +.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #7 of 13 Old 08-06-2010, 11:27 AM
2006_Sport
2006_Sport's Avatar
It is quite annoying
post #8 of 13 Old 08-06-2010, 01:41 PM
VTJeePTJ
Yep, fairly normal and I had this when I was stock too. I now run 4.88's and 35s and wish I could go to 5.38's. I run with OD off all the time until I am cruising at least a constant 65+ mph
96 ZJ - 5.2 V8, Claytons, D44/ARB's f&r, Atlas 3.8, 35's
VTJeePTJ is offline
post #9 of 13 Old 08-06-2010, 01:46 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your engine is probably just lugging at such a low rpm. 1600 rpm is just too low of an engine rpm for a Jeep Wrangler at 50 mph.
Jerry Bransford is offline
post #10 of 13 Old 08-06-2010, 01:49 PM
Unlimited04
or maybe the 42RLE shouldn't shift into OD at 38mph, and lockup in OD at 45mph...it should stay in 3rd until 53mph with 3.73s/30s.
Useful Write-Ups:
Funny:
post #11 of 13 Old 08-06-2010, 01:58 PM
Jerry Bransford
Administrator
Hah that too.
post #12 of 13 Old 08-06-2010, 02:08 PM
AKABOB
Incredibly Handsome
AKABOB's Avatar
would that cause any problems of loosening bolts/nuts? I remember years ago a Detroit engine in a 379 Peterbilt would have a resident noise (i think that is what is called) that would shake off the alternator. folks had to go up to a 34 alt to get the fourth bracket. The frequency for that particular cubic space vibrated stuff to death?
AKABOB is offline
post #13 of 13 Old 08-06-2010, 03:41 PM Thread Starter
LJinNOLA
Yeah it seemed fairly normal so I assumed others had it and I usually turn off the OD going up that incline, simply because I need the power and it DOES indeed get annoying. One of these days I'll probably go with some 4.88s and 33s so it will lug less then.
It does seem like it could easily be a frequency vibe from the t-case because it seems like the floor right under my feet is the strongest vibe.
I kept trying to hold out for a manual LJ, but my 04 was too good of a deal to pass up. I've lived with this for almost a year and a half, so I think I can keep living with it.
LJinNOLA is offline
vibes , vibration , od , overdrive , lj , wrangler
06 Rubicon 42RLE Drivetrain Problems Cheney TJ Wrangler Technical Forum 1 04-10-2009 08:15 PM
BB Vibes 32RH vs. 42RLE UnsanePyro TJ Wrangler Technical Forum 2 11-07-2008 02:28 PM
stock drivetrain and 35s sk80soarus YJ Wrangler Technical Forum 16 09-27-2007 11:03 AM
Drivetrain vibes ColoradoTxJeep TJ Wrangler Technical Forum 4 08-05-2007 01:16 PM
What's causing my vibes? MikieB TJ Wrangler Technical Forum 19 10-01-2006 10:44 PM
