4'' Suspension lift questions!?! - JeepForum.com
post #1 of 2 Old 08-30-2010, 12:54 PM Thread Starter
sbrendan420
I have my tj in the shop to put a Superlift Superride 4'' suspension on it. I also bought a SYE and extended driveshaft for it. The mechanic called and said 1. the back of the jeep sits lower than the front and 2. there is vibrations when you reach about 45-50 mph.
Any and all advice would be appreciated, Thanks again!!
sbrendan420 is offline
post #2 of 2 Old 08-30-2010, 01:04 PM
-dirt-
-dirt-'s Avatar
Did you buy a CV driveshaft or just an extended non-CV driveshaft?
A CV shaft will require the pinion be tilted up to be inline with the driveshaft (as seen in the 1st pic here: Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist) in order to avoid vibes.
More info here: What is a CV shaft and why do I want one? - JeepForum.com
-dirt- is offline
suspension , lift , 4" , superlift
Suspension lift questions, please help... chickenhawk7 JK Wrangler Technical Forum 14 02-16-2009 06:01 AM
4'' Suspension Lift Questions Xrangler TJ Wrangler Technical Forum 1 03-30-2008 06:22 PM
4" suspension lift questions wakeboardjeep TJ Wrangler Technical Forum 13 07-23-2007 12:17 PM
Newbie suspension lift questions edzakory TJ Wrangler Technical Forum 4 05-22-2006 04:33 AM
Suspension Lift, Body Lift Questions CityJeep TJ Wrangler Technical Forum 2 06-12-2005 04:52 PM
