4.0L Woes...Bogging down on acceleration?? - JeepForum.com
post #1 of 13 Old 06-27-2010, 03:20 PM Thread Starter
Hella
Okay so the last week has been hella with this 4.0L. It started with a misfire on a few cylinders and I finally fixed that today. So I took it for a ride and now the engine bogs down bad on acceleration. Gas mileage has seem to be crappy also. Also hear a rattle coming from underneath the jeep, almost sounds like a trans problem but maybe cat? Also after I stop driving I hear a ticking coming from underneath the valve cover. Just curious if anyone can help me out and point me in the right direction. Thanks in advance
04 TJ "Leyla" Rubi..
Hella is offline
post #2 of 13 Old 06-27-2010, 03:32 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
How did you fix the cylinder misfires?Did you replace the plugs?If so,which ones exactly?Could need the throttle body cleaned.Were you getting any codes?Please elaborate a bit more on how this whole thing started.
GOLENJEEPTJ is offline
post #3 of 13 Old 06-27-2010, 03:54 PM Thread Starter
Hella
The whole situation started driving down the freeway and I got a misfire. Which is right after I got some cheap gas. I talked to my uncle who is a mechanic and he said to try to replace the cam sensor. Well I replaced the cam and crank sensor today and got fresh gas and took it for a ride. I got on the freeway and drove it and it only missed once. The code didnt store in the computer so I couldnt see what cylinder. Was coming back down the freeway and it seemed like it was bogging bad and I was dumping gas bad also. Got off the freeway and now when I accelerate it bogs bad. It dropped a quarter of a tank driving about 25 miles and no check engine light. In park or neutral the engine will rev out but it def seems sluggish and takes a while to get through the RPMs. Getting confused more everyday.
It was cylinder 4,5 and 6 when it was misfiring the first day...Pulled the plugs that night and they looked fine so I didnt replace them. It was only misfiring while I was on the freeway...
Hella is offline
post #4 of 13 Old 06-27-2010, 04:12 PM
mkleza
sounds like it could be the cat. Get under the jeep after the exhaust has cooled down and give the cat a pretty good hit, if it rattles then it is shot.
mkleza is offline
post #5 of 13 Old 06-27-2010, 06:45 PM Thread Starter
Hella
not the cat we figued out...still bogs on acceleration.
Hella is offline
post #6 of 13 Old 06-28-2010, 03:36 AM Thread Starter
Hella
bump for help, please!
Hella is offline
post #7 of 13 Old 06-28-2010, 04:09 AM
cosmo05
Mine did the same thing, it was the O2 sensor, the one in the front on the exhaust header.
cosmo05 is offline
post #8 of 13 Old 06-28-2010, 09:54 AM Thread Starter
Hella
was your check engine light on?? Just curious. If not then it looks like im going to be throwing o2 sensors at it...
Hella is offline
post #9 of 13 Old 06-28-2010, 10:32 AM
cosmo05
Yes, it would come on, then go out for awhile and then come back on. I did check it with a hand held computer diagnostic but it not indicate an O2 sensor for some reason. Run a diagnostic on it anyway and see what it comes up with. The other thing I would get in addition to what your described was occasional pops out the throttle body.
cosmo05 is offline
post #10 of 13 Old 06-28-2010, 10:36 AM
mdm
Farm Wheeler
Cat doesn't have to rattle to be bad.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #11 of 13 Old 06-28-2010, 11:25 AM
Unlimitedlou
Unlimitedlou's Avatar
I was running in to the same problem and I finally figured it out. Your oil pump drive assy and mine are different, but just by a little bit. The rattling you are hearing may be due to the shaft moving in the top bushing of the oil pump drive assy. I experienced all the same problems as you, with no CELs. Eventually it gets worse. Put your hand on it while it is running and you can feel it. Just trying to point you in another direction.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #12 of 13 Old 07-02-2010, 07:39 PM
SnoqulmieTJ
Bump
SnoqulmieTJ is offline
post #13 of 13 Old 07-02-2010, 11:08 PM
aspjeepguy
2016 JK Wrangler
Mine did what you are describing. It started to misfire on the middle two cylinders. Then it would run but as soon as you got up to highway speed the jeep would seem to miss bad. What I found out was that the screen in the gas tank was plugged.
The jeep ran like a top after I did that and that was 30k ago
aspjeepguy is offline
loss of power , acceleration
Bogging down when hot Photojeep TJ Wrangler Technical Forum 8 11-02-2009 08:50 AM
99 TJ 4.0 bogging.... petej200 TJ Wrangler Technical Forum 2 02-28-2009 09:14 AM
Bogging down in 5th bbunn1 YJ Wrangler Technical Forum 5 06-20-2006 01:03 PM
YJ bogging out....AHH! KBwithaJEEP YJ Wrangler Technical Forum 9 03-03-2006 10:49 AM
Engine Bogging Down AeroE YJ Wrangler Technical Forum 1 02-10-2005 11:53 AM
