4.0 TJ Header Install Write-up?? - JeepForum.com
post #1 of 9 Old 03-20-2006, 10:57 AM Thread Starter
chilijeep
Guest
Does anyone know where there is a write-up on installing a header on my 4.0?? Mine has cracked for the 2nd time (even with the expansion joints) and I have to replace it again and have one sitting in the garage ready to go on but I just want to make sure I do it right.
chilijeep is offline
post #2 of 9 Old 03-21-2006, 10:47 AM Thread Starter
chilijeep
Guest
Back to the top!
post #3 of 9 Old 03-21-2006, 10:56 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2020 J-Series Truck
As many times as I've done this, I should have a write-up, but I don't. Sounds like you've done this before, right?
Well, maybe this will help:
Tightening sequence:
And torque values:
After you install it, go out and drive for 15 minutes or so. Then re-torque all the bolts.
Wheelin98TJ is offline
post #4 of 9 Old 03-21-2006, 11:01 AM
NakedJeeper
NakedJeeper's Avatar
Installing Banks headers on a 4.0L
http://www.nakedjeep.com/Projects/TTubes/TTubes01.html
NakedJeeper is offline
post #5 of 9 Old 03-21-2006, 11:13 AM
Wheelin98TJ
JEEP FREAK
2020 J-Series Truck
Originally Posted by NakedJeeper
Nice write-up.
But you don't have to remove both the injectors and disconnect the fuel line. Either do one or the other.
post #6 of 9 Old 03-21-2006, 12:29 PM Thread Starter
chilijeep
Guest
And torque values:
Thanks for the help. I've had to replace it before but I was busy and just had the shop do it. Saving pennies for vacation so I thought I would tackle it myself this time. How long did the install take and what all did you have to remove besides the header??
post #7 of 9 Old 03-21-2006, 12:36 PM
NakedJeeper
Nice write-up.
I disconnect the electrical connections to the injectors, not the injectors.
To remove the intake, which the fuel rail is attached to, you kinda have to disconnect the fuel line.
post #8 of 9 Old 03-21-2006, 01:09 PM
Wheelin98TJ
JEEP FREAK
2020 J-Series Truck
Originally Posted by chilijeep
... How long did the install take and what all did you have to remove besides the header??
I've got it down to a 2 hour project, but I've done this 5 times now.
You also have to remove:
-Intake manifold(I know this is obvious, just wanted to give you a complete list)
-Air intake tube
-Fuel injector electrical plugs
-Fuel injectors or fuel line. If you don't have a fuel line disconnect tool, you have to remove each injector. Its probably easier to just buy the disconnect tool for maybe $5 or $10.
-Everything connected to the throttle body
-Vaccuum line on the intake manifold
-Power steeering pump
I think thats everything.
That write-up NakedJeeper posted should be some help to you too.
Oh, my fault. I read that rather quickly and must have misread what you wrote. I thought you removed the injectors and disconnected the fuel line.
post #9 of 9 Old 01-01-2015, 09:58 PM
Jeeppperrrr
Im in the process of replacing my intake gasket. Do you guys have any tips or tricks to get at the bolts on the bottom side? I can see two of them but dont even know how id get at them... thanks!
Jeeppperrrr is offline
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 07:59 PM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 10:10 PM
Brake install How-To Write up?? bam9382 TJ Wrangler Technical Forum 8 05-13-2005 08:43 AM
write up for header install? 6Speed TJ Wrangler Technical Forum 2 05-27-2004 09:49 PM
Banks Header install Write up? soccergk2003 YJ Wrangler Technical Forum 3 12-22-2003 01:30 PM
