4.0 Motor swap - Pilot bushing/sleeve for auto trans? - JeepForum.com
 1Likes
  • 1 Post By Red Rubicon
post #1 of 9 Old 12-02-2019, 01:56 PM Thread Starter
uhohthe50
uhohthe50's Avatar
I'm working on replacing the 4.0 in a 2005 wrangler with another 4.0. The new (but slightly used) motor is originally out of a 03 Grand Cherokee. I have the new motor ready to go in, however I noticed it does not have the same bushing that the old motor had on the crankshaft where the motor meets the trans.
There is a bushing/sleeve in the old block that has an inner diameter that matches up to the front hub on the torque converter. I think that bushing/sleeve is needed to align and hold some of the weight of the torque converter. Can anyone confirm that is the case? Or am I over thinking it? Are the 4 bolts that mount the torque converter to the flex plate enough? It doesn't seem correct not having the id of the bushing on the crank match the od of the hub on the torque converter. If I bolt the new motor up how it currently sits, the hub on the front of the torque converter will be about a half an inch smaller than the diameter of the hole on the end of the crank.
I've been searching all over the place for info about it but all I seem to come across are posts about pilot bearings for manuals. I can't seem to find a replacement bushing anywhere. Last night I tried renting a pilot bearing puller from autozone to get the old bushing out, however the bushing sits directly against the crank. There is no room to get behind it with the puller arms. I also tried the bread trick , but again, there really isn't a gap on the back side of the bushing for the bread to get behind it.
Has anyone else ran into this before? Any suggestions?
My 1990 YJ Build Thread: https://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline
post #2 of 9 Old 12-03-2019, 04:45 AM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
I thought that only manual trannys needed the PB & the auto's didn't
BlueFl.Wrangler is offline
post #3 of 9 Old 12-03-2019, 06:02 AM Thread Starter
uhohthe50
uhohthe50's Avatar
Here's a pic of the sleeve/busing that is in the crankshaft of the old motor I pulled out of the jeep.
https://www.jeepforum.com/forum/atta...875153&thumb=1
Here's the new motor with the flex plate installed on it. Notice it doesn't have the bushing in the end of the crankshaft.
https://www.jeepforum.com/forum/atta...875155&thumb=1
And here's what the nub looks like on the torque converter. Notice it is tapered a bit. The end of it is almost the same exact size as the id of the bushing (within .01") when I measure it.
https://www.jeepforum.com/forum/atta...875151&thumb=1
post #4 of 9 Old 12-03-2019, 12:11 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
It might work OK without it but I wouldn’t want to chance it. Besides supporting the converter (probably the most important thing) it will also help line up the converter when bolting it to the flex plate. You don’t want to end up with vibrations from the converter not being properly lined up & also it might cause excessive wear to the trans.
If you can’t get the sleeve (bushing) out of the old crank try finding a new one.
It looks like you need part # 04736204AA which shows as discontinued but I did see it may supersede to 04736483AA.
https://www.factorychryslerparts.com...ey_model=15533
Does not show a listing for item #7 (usually means discontinued) which is the sleeve for automatics but if you put 04736204AA into the search function you get
https://www.factorychryslerparts.com...4736204AA.html
Then look down in the also bought you see “BEARING, SLEEVE. Crank Shaft Pilot, Pilot. Automatic Transmission” which takes you to
https://www.factorychryslerparts.com...4736483AA.html
Which says here “Part Number: 04736483AA
Supersession(s):04736204AB; 4736483AA”
I would do some further checking to see if 04736483AA works or even do more searching with the 04736204AA number.
Rubi4MyMrs is offline
post #5 of 9 Old 12-03-2019, 12:38 PM Thread Starter
uhohthe50
uhohthe50's Avatar
I was thinking the same thing that I didn't want to chance it.
I appreciate the info, you got further than I could in searching for it. 04736204AA definitely looks to be the part. That sucks it's been discontinued though. At least I have a part number to go off of now.
04736483AA does look just like the sleeve thats in the motor. I wish they had dimensions for it so I could tell if it is for sure the same size. I'm going to keep searching around to see if I can find some dimensions for it or if I happen to get lucky and find someone with the original part (04736204AA). Thanks again!
post #6 of 9 Old 12-03-2019, 12:55 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Here is a link I found when searching. It is from 2013 & a national search did not find one part back then. He claimed to have one machined from the manual trans pilot bearing.(?) Also may have had converter issues without the sleeve.
https://www.jeepforum.com/forum/f9/n...nions-1480737/
post #7 of 9 Old 12-04-2019, 09:40 AM
Red Rubicon
Have you tried a transmission shop? They should either have one or have a source to get one.
jjandascog likes this.
Red Rubicon is offline
post #8 of 9 Old 12-16-2019, 06:38 AM Thread Starter
uhohthe50
uhohthe50's Avatar
In case anyone runs into this in the future, I ended up ordering 04736483AA since it looked like the same sleeve in the pictures. Surprisingly it ended up being the exact same part and fit perfectly. Thanks again Rubi4MyMrs for finding that!
post #9 of 9 Old 12-16-2019, 10:21 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Thanks for posting results. Discontinued parts are becoming a real issue for our “old” TJs.
Finding equivalent parts is a challenge. I found this almost by accident so good to know it works.
