32's or 33's hard to decide - Page 2 - JeepForum.com
post #16 of 23 Old 10-10-2009, 11:03 AM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
I bought the 33x10.50's.
Taller, lighter, etc.....
Read my build thread about why I chose that size.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #17 of 23 Old 10-10-2009, 04:14 PM
CCJ
You might want to have some experience before giving bad advice.My brother has had 33's and mounted on the stock spare tire carrier for several years.MrBlaine's wife has a 35" spare mounted on the stock tire carrier.You just have to get the weight on the bumper and off the tailgate.
Originally Posted by inmate001 View Post
how do you get the weight of the tire off of the tailgate and on the bumper
LOL I was wondering the same thing.
CCJ is offline
post #18 of 23 Old 10-10-2009, 04:58 PM
BoarderX47
X2. If you mount it correctly so the tire is tight against the body it will be fine.
Jeep TJ Tire Carrier on Tailgate and Larger Spare
BoarderX47 is offline
post #19 of 23 Old 10-10-2009, 06:55 PM Thread Starter
inmate001
my next question is what tires you recommend Im looking for something that handles ice well but i also like the rocks so i need something with good side walls i don't like mud but I do get into it often enough for it to be a concern price also is a factor
inmate001 is offline
post #20 of 23 Old 10-10-2009, 10:02 PM
2003X
2003X's Avatar
2014 JK Wrangler
bump bump bump
I have my rear tire on a swing out carrier, which is on the bumper.
My Build
2003X is offline
post #21 of 23 Old 10-10-2009, 10:03 PM
Jeepster83
like this...
happened kind of by default for me though. i got the bumper long before i got my tires (33x10.50) and the tire shop told me it wouldnt fit. i had them put it in the back and i went home and put it on myself. it rubs a little bit when opening and closing but its nothing that bothers me in the slightest. i actually like how snug it is.
back on topic now.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #22 of 23 Old 10-11-2009, 12:28 AM
Jeepster83
for the snowy and icy conditions you need a lot of tread contact and contact pressure. a skinnier tire will give you better contact pressure than a wider tire and one with a fairly tight tread pattern will give you the tread contact. as you can see in my picture above i have BFG AT's and they work great in snow and ice. they do okay on rocks but are clearly not a tire designed for rocks but they do have a very strong, 3-ply sidewall. in mud they pack up pretty quick and become slicks but theyre not the worst tire you could have in mud.
my vote goes to either the BFG AT for all-around performance (as per your criteria) and the BFG KM2 for better performance in the rocks and mud (youll lose a little in snowy/icy conditions though).
post #23 of 23 Old 10-11-2009, 01:09 AM
Silver_Slipper
Silver_Slipper's Avatar
check out the Goodyear Dura trak's. they've been getting rave reviews by not only me but others as well! They are also pre-drilled for snow/ice studs for winter.
Wheel it like a rental car!
My Jeep and I both wave. :D
Silver Jeep Club #37
Nightcrew #021
|l,[___],
l---L--OlllllllO
()_) ()_)--o-)_)
"The Jeep is America's only real sports car" - Enzo Ferrari
Originally Posted by MarkoPo View Post
No, we all know in the beginning God created the earth and the Heavens. On the second day God created man and Jeep. Man had too much fun so God created woman. Man hasn't had near as much fun since.
Silver_Slipper is offline
why 33's & not 32's plumber1 YJ Wrangler Technical Forum 13 07-01-2009 09:28 PM
31's vs 32's - Help me decide Igetit TJ Wrangler Technical Forum 26 03-19-2009 10:35 PM
TIRE SWAP! 31's to 32's and 32's to 33's *PICS* thejafe TJ Wrangler Technical Forum 69 05-13-2007 05:37 PM
33's or 32's cpd806 JK Wrangler Technical Forum 2 03-07-2007 06:01 AM
Help me decide, anyone with 32's and 3 speed auto with 4.10's? sgrim80 TJ Wrangler Technical Forum 6 09-23-2005 08:04 PM
