31x11.50 fit? - JeepForum.com
post #1 of 10 Old 01-20-2009, 10:11 AM Thread Starter
MC_NickP
MC_NickP's Avatar
31x11.50 fit?
i have a stock 98 tj with no lift what so ever. will a 31x11.50 tire fit without rubbing? my rim has 4" backspacing
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
MC_NickP is offline
post #2 of 10 Old 01-20-2009, 10:18 AM
Bmel17
Bmel17's Avatar
https://www.jeepforum.com/forum/showthread.php?t=447831
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
post #3 of 10 Old 01-20-2009, 10:23 AM Thread Starter
MC_NickP
MC_NickP's Avatar
im trying to interpret the chart. am i safe with the 4"?
Black 98 TJ
build thread:
MC_NickP is offline
post #4 of 10 Old 01-20-2009, 10:32 AM
Bmel17
Bmel17's Avatar
at full lock it might, you will want to extend your bumpstops. If you don't wheel at all you should be good.
08 HD Nightster
Bmel17 is offline
post #5 of 10 Old 01-20-2009, 10:41 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
It will be fine with 4" wheel backspacing.
TheBoogieman is offline
post #6 of 10 Old 01-20-2009, 10:43 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The tires will fit fine.
What is confusing you with the chart? Maybe there is something I missed that would make it more clear.
Wheelin98TJ is offline
post #7 of 10 Old 01-20-2009, 10:54 AM Thread Starter
MC_NickP
MC_NickP's Avatar
it just says x backspacing or less... on all of them. it was just confusing at first, but now i got it
Black 98 TJ
build thread:
MC_NickP is offline
post #8 of 10 Old 01-20-2009, 10:59 AM
Wheelin98TJ
JEEP FREAK
I can see how it could be confusing.
The X's represent the metric tire measurements that are not relevant to the width of the tire. (height and wheel diameter)
I'm going to fix this so hopefully its more clear.
post #9 of 10 Old 01-20-2009, 11:01 AM Thread Starter
MC_NickP
MC_NickP's Avatar
so for example 4" backspacing, i couldnt tell if everything above that will fit, or everything under will. do you understand what i had problems with?
Black 98 TJ
build thread:
MC_NickP is offline
post #10 of 10 Old 01-20-2009, 11:11 AM
Wheelin98TJ
JEEP FREAK
Here is how to use the chart:
1. Find your tire size.
2. Then follow that row over to the column that reads "Recommended Backspacing".
So for example, 11.50 tire width - it says 5" or less. Therefore 4" will work fine.
which tire for the 2.5L? 32x10.5 or 31x11.5 MC_NickP TJ Wrangler Technical Forum 11 05-16-2010 11:30 PM
Tire Recomendation - 31X11.5R15 Bam_19 Wrangler General Discussion 0 02-17-2009 09:15 PM
31x11.5 TSL Radials on Ecco's sweetguardian00 TJ Wrangler Technical Forum 7 04-23-2008 09:57 AM
31x11.50 on yj pyrohil YJ Wrangler Technical Forum 11 09-24-2007 10:33 AM
Can I Do 31x11.5 's? HARBIE '95 YJ Wrangler Technical Forum 5 08-29-2006 06:26 PM
