2006 TJ Rubicon Unlimited 2 dr. 4 X 4 LWB - JeepForum.com
 22Likes
post #1 of 70 Old 07-06-2020, 09:54 AM Thread Starter
Frank Slap
Frank Slap's Avatar
Hello Everyone,
I'm a New Member
I just bought my first Jeep, It's got a lot of miles (210,000)
What should be my first concerns as to it's Maintenance /Safty? ...(timing belt/chain, Suspension bushings/components) Please give me your thoughts......
I was told that it runs & drives great. I'm the 3rd owner, clean Car fax, Vehicle is stk. clean & straight.
I get/look at it in 2 weeks. I hear they are prone to frame rot in front of rear wheels. It was recently under coated....
Regards,
Frank
Frank Slap is offline
post #2 of 70 Old 07-06-2020, 10:02 AM
Duck Doctor
Did you inspect the undercarriage to verify the frame is not rotten? Frame condition would be my primary concern given your location. Automatic or manual transmission?
Frank Slap likes this.
Duck Doctor is offline
post #3 of 70 Old 07-06-2020, 10:16 AM
natedenver
2006 was the last year of the tj. Assuming you got the 4l 6cyl, you should be in good shape. Because of the high miles i would take it to a trusted mechanic to check wverything over under the hood.
natedenver is offline
post #4 of 70 Old 07-06-2020, 10:20 AM Thread Starter
Frank Slap
Frank Slap's Avatar
6 sd.man. w/od. I'm doing the trans. online Its 2 hours away in L.I. N.Y. I'll check it out in person in 2 weeks, where do I look?
post #5 of 70 Old 07-06-2020, 10:31 AM Thread Starter
Frank Slap
Frank Slap's Avatar
I look @ it in 2 wks. I'm very mech. inclined I've had a lot old muscle cars (2 ) 71 camaros (still have the z28, Datsun 240z, 77 z28 81 buick electra estate Full size wagon & I'm on my 3rd boat ....I rebuiul the hull & jot new interior 18' Runabout 3.0L 200 hp. I have maintained them all my self I have a lot of tool & enjoy maintaining them.... But this it the newest year for me I like the old stuff that you con work on ...I also restored a 68 Triumph motor cycle, 800 big bore kit road race cams w/ big Amal carbs.
I'm in new territory w/this one.
post #6 of 70 Old 07-06-2020, 10:48 AM
natedenver
Well you should get aling fine with the tj. Last year where everything under the hood is very accessible. I changed my radiator out in 40 minutes total. Alternator was 30 minutes. I had never changed either before on any wlvehicle.
Sent from my LM-G820 using Tapatalk
post #7 of 70 Old 07-06-2020, 10:58 AM Thread Starter
Frank Slap
Frank Slap's Avatar
NICE, Thank you for your reply. That's Good to hear.
post #8 of 70 Old 07-06-2020, 11:32 AM
Duck Doctor
You need to crawl under the rig and probe the frame with a hammer and screwdriver. Quite common for sellers to hide rot with expanding foam and a fresh coat of paint.
I wouldn’t even bother with maintenance items until I verified that the frame is sound.
post #9 of 70 Old 07-06-2020, 11:53 AM
2jhanna
The recent undercoating would be a red flag to me.
Why did the current owner wait 14 years, 200k miles to protect the frame.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #10 of 70 Old 07-06-2020, 02:22 PM Thread Starter
Frank Slap
Frank Slap's Avatar
Is this a stamped sheet metal frame (uni body) or is it separate part? Where are they prone to rot ?
post #11 of 70 Old 07-06-2020, 02:27 PM Thread Starter
Frank Slap
Frank Slap's Avatar
I miss spoke earlier, I'll technically will be the 3rd owner...I'm buying it through a used jeep auto seller. Dealer. I'm Concerned about the frame rot & told them about it & the recent under coating job that they did. (i'd rather see a lightly rusted frame than a FRESH Under Coat job. <>< ' EEE
post #12 of 70 Old 07-06-2020, 02:38 PM
2jhanna
A TJ has a separate frame, not uni-body. And is frame and other parts are very, very, very prone to rust and rot out, especially in salty areas near the coast, and wear salt is used on northern roads.
Pretty much every couple weeks is a new thread here where some one has a rotted out frame.
jhanna
denton county, tx
2jhanna is offline
post #13 of 70 Old 07-06-2020, 02:40 PM Thread Starter
Frank Slap
Frank Slap's Avatar
Oh No, Is there any "hot spot " for that frame rot ??
Why wouldn't Jeep " FIX " this flaw in their design... If it is SO prevalent.
post #14 of 70 Old 07-06-2020, 02:49 PM
Duck Doctor
These rigs haven’t been built in 14 years so no reason for Chrysler to repair. Frames rot because owners neglect the undercarriage and fail to clean regularly during the winter. Play close attention to the area around the skid plate. Feel/look inside the frame for rot and heavy metal flakes.
post #15 of 70 Old 07-06-2020, 02:58 PM Thread Starter
Frank Slap
Frank Slap's Avatar
From what you said, If their so Prone to frame rot than other Vehicles.... That's why I said that It seems to be Jeep design prob. in general. Some times the matl. they source is more prone to rot. I'll have to look close at that for rot. Thanks for your Advice ! Much Appreciated !!
Where's the Skid Plate ??
