2006 LJ Rubi - ongoing issues. Desperate - JeepForum.com
post #1 of 27 Old 05-28-2020, 10:38 AM Thread Starter
Jonloder
2006 Rubicon Unlimited 4.0 6-speed manual
I had issues with readiness sensors when the thing was just a year or so old. There was a TSB put out that involved re-routing some wiring in the fuse box. Around 2013, I finally got the local dealer that I bought the Jeep from to perform the procedure and it immediately went to ready state and I had no problem passing smog. This may or may not matter to the current issue...
It started with a barely detectable miss when taking off from idle. Over the months, it evolved into a hesitation and, eventually, a full stall. After a while, it got to where it was hard to start after the stall. I got trapped in an intersection more than once. I also began to notice that all of the sensors were not in readiness state after a stall. After getting some advice on a paid, technical forum, I tried resetting the plugs in the PCM. That always made the problem go away. Sometimes for a few hours. Sometimes for several days. The issue, as the tech support opined, seemed to be a voltage deficiency. I drove it like that for a year or so. Whenever I felt the stall issue start to come on, I reset the PCM plugs. That's no longer working. I sent the PCM in for a rebuild. They assured me that there was a programming error and it just needed reprogrammed. The hardware itself tested good. As it turned out, the reprogramming made zero difference.
I now have a Rubicon Unlimited sitting in my driveway with no way to get it registered or even running again. The voltage deficiency idea seemed to have merit but I've gone through every connection I could find. Either there's another issue that I haven't found yet or the reprogramming people failed to fix the real problem.
I sure could use some ideas on what to try next. Thank you for any help.
Jonloder is offline
post #2 of 27 Old 05-28-2020, 11:03 AM
jtec
jtec's Avatar
2014 JK Wrangler
If the monitors are resetting to not ready it seams they are loosing power. maybe go over the 'repairs' that were done with the TSB, the splices, connections.
TSB #25-001-07
jtec is offline
post #3 of 27 Old 05-28-2020, 11:04 AM
jkp
If the voltage is low, the voltage regulator is in the PCM.
What voltage are you measuring?
No codes?
'92 Islander
'06 Rubicon
jkp is offline
post #4 of 27 Old 05-28-2020, 11:20 AM Thread Starter
Jonloder
TSB #25-001-07
Thanks for the reply. That's actually one of the the first things I did. The connections look very well done with shrink-wrap. I haven't cut them open to look at the soldering but they feel very solid.
Jonloder is offline
post #5 of 27 Old 05-28-2020, 11:24 AM Thread Starter
Jonloder
No codes?
No codes. Just a lot of "not ready"
I don't remember the numbers but I measured at battery and at alternator, at idle and not running. No obvious issues.
Jonloder is offline
post #6 of 27 Old 05-28-2020, 11:34 AM
jkp
Check the wiring harness at the back of the valve cover for chaffed wires, there's a known problem there. Not sure if it would cause this problem, but easy to check.
'92 Islander
'06 Rubicon
jkp is offline
post #7 of 27 Old 05-28-2020, 12:26 PM
mukluk
mukluk's Avatar
Based on this: "I tried resetting the plugs in the PCM. That always made the problem go away. Sometimes for a few hours. Sometimes for several days. The issue, as the tech support opined, seemed to be a voltage deficiency. I drove it like that for a year or so. Whenever I felt the stall issue start to come on, I reset the PCM plugs. That's no longer working", I would suspect that your issue is caused by loose terminals in at least one of your PCM plugs, most likely plug C1. The female terminal pins in the plugs can be easily damaged/spread with meter probes if you're not careful, afterwards they will not make good reliable contact with the male pins in the PCM sockets. Additionally, repeated or forceful reseating of the plugs can damage the locking feature for the plug's terminal pins, allowing the pins/wires to recess into the plug when you try to connect it to the PCM.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #8 of 27 Old 05-28-2020, 12:40 PM Thread Starter
Jonloder
Thank you for the response. I was concerned about this from early on. The reason that I've discounted it as being significant here is that I could get the same effect by disconnecting the battery. Therefore, it's nothing to do with the PCM plugs but simply a matter of power cycling the PCM. It seems like all roads lead to the computer. I still haven't got a response from G7 Computers. They seem to be on Covid shutdown or something.
Jonloder is offline
post #9 of 27 Old 05-28-2020, 12:46 PM
mukluk
mukluk's Avatar
If you're heavily leaning toward the PCM, Wranglerfix seems to be getting quite a bit of good reviews on several forums for their new manufacture units.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #10 of 27 Old 05-28-2020, 01:10 PM Thread Starter
Jonloder
I admit that I'm on the verge of shotgunning the $1k option. That's a big chance to take.
Jonloder is offline
post #11 of 27 Old 05-28-2020, 01:59 PM
mukluk
mukluk's Avatar
I personally abhor shotgunning parts, especially so expensive ones.
Could you explain exactly what you did when "going through" all the connections you could find?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #12 of 27 Old 05-28-2020, 02:14 PM Thread Starter
Jonloder
Battery terminals, ground straps, etc. I also used electrical cleaner in plugs at the PCM.
Jonloder is offline
post #13 of 27 Old 05-28-2020, 02:25 PM
mukluk
mukluk's Avatar
At minimum I would advise using a meter to verify the quality of your grounds and voltages getting to the PCM C1 plug. You want to see as near to zero ohms as possible checking continuity to ground at pins 9 and 18, and as near as possible to actual battery voltage (across the terminal posts) when checking for voltage at pins 11 and 29. On a side note, your battery should read 12.6v across the terminals when fully charged -- if lower than that, charge the battery or take it to be load tested.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #14 of 27 Old 05-28-2020, 03:35 PM Thread Starter
Jonloder
At minimum I would advise using a meter to verify the quality of your grounds and voltages getting to the PCM C1 plug. You want to see as near to zero ohms as possible checking continuity to ground at pins 9 and 18, and as near as possible to actual battery voltage (across the terminal posts) when checking for voltage at pins 29 and 30. On a side note, your battery should read 12.6v across the terminals when fully charged -- if lower than that, charge the battery or take it to be load tested.
I replaced the battery because the fully charged voltage was "marginal." I think that was sales speak for "I want to sell you a battery."
Do you happen to know where I may find a pinout diagram?
Thanks.
Jonloder is offline
post #15 of 27 Old 05-28-2020, 03:37 PM
mukluk
mukluk's Avatar
There is a pinout diagram for C1 attached in my previous post.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
