2005 Wrangler Unlimited nsg370 noise help - JeepForum.com
post #1 of 5 Old 06-05-2019, 04:35 PM Thread Starter
PaYankee
Hello. My 2005 lj nsg370 is making a bibrating noise that is coming from the bell housing/slave cylinder area. It is almost the same noise that a looseexhaust heat shield might make. The noise stops whenever the clutch is pressed.
Here is a video of the noise. Any help is appreciated.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline
post #2 of 5 Old 06-06-2019, 03:21 PM
TJnBC
Throwout bearing and/or the clutch fork return spring is broken.
You can remove the slave cylinder, and push on the fork through the hole. If the fork is still tight and doesn't "chatter" when you press in on it, then it is your TB.
Mine has done this forever. They are known to be noisy. Even after putting a new National metal TB on, 3 weeks later it makes noise sometimes.
2006 LJR...the madness begins again
TJnBC is online now
post #3 of 5 Old 06-08-2019, 07:06 PM Thread Starter
PaYankee
I have ordered a luk clutch, national and Timken throwout and pilot bearing, and some other parts. Going to be pulling the transmission next week.
PaYankee is offline
post #4 of 5 Old 06-09-2019, 05:21 PM
WeezyBlue
Another vote for throwout bearing. I just did mine 2 weeks ago, as I slid it back it dumped bearings everywhere. I put a National brand in as well, TJnBC's comment is a bit disappointing
KD8UCX
05 TJ Rubicon DD
82 Wagoneer Limited WIP
06 TJ SE Sold
WeezyBlue is offline
post #5 of 5 Old 06-10-2019, 10:10 AM
TJnBC
Sorry to disappoint. You may get lucky but the 6 speeds are known to be noisy.
Even after you put a new National OR Luk TB, it will eventually be noisy again, timing is the question.
TJnBC is online now
