2005 TJ with 285/75/16, 4.56 or 4.10 and A/T - JeepForum.com
post #1 of 13 Old 11-01-2011, 08:46 AM Thread Starter
ckalogris
Does anyone have this setup? Can you tell me the rpm you get at 60mph, with the OD? Any pics?
Thanks!
ckalogris is offline
post #2 of 13 Old 11-01-2011, 09:53 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
MPH x Gear Ratio x 336 x OD ratio
--------------------------------- = RPM
Tire size
Or you can plug the #s in here:
http://www.csgnetwork.com/multirpmcalc.html
4 speed OD ratio = 0.69 (round up to 0.70 for drivetrain loss)
285/75/16 = 32.8" tall (round down to 32.4" since actual tire height is often less than calculated height)
Wheelin98TJ is offline
post #3 of 13 Old 11-01-2011, 09:58 AM
Mortalis5509
4.88
Go DAWGS
Mortalis5509 is offline
post #4 of 13 Old 11-01-2011, 10:07 AM
touched
05 Rubicon with A/T,4.10 gears, 285\75\16 MTR's,60 mph is about 1800rpm.
Rokmen TT,Savvy GTS, JKS BL MML,Orr-Fab sport Cage,Rock Hard front bumper,Body Armor side bars,Best rear bumper
Currie HD Steering , Savvy 4" lift, Fox shocks
touched is offline
post #5 of 13 Old 11-02-2011, 06:28 AM Thread Starter
ckalogris
thanks Wheelin98TJ! very useful formula and comments
Mortalis5509, do you suggest to go with 4.88?
touched, what lift do you have?
post #6 of 13 Old 11-02-2011, 06:31 AM Thread Starter
ckalogris
also, touched, did you need wheel-spacers? is there any rubbin?
post #7 of 13 Old 11-02-2011, 08:08 AM
touched
Savvy 3" lift, I didnt use spacers,had some rubbing in the front at full lock. I just put a few washers behind the stops.
touched is offline
post #8 of 13 Old 11-03-2011, 01:17 AM
Mortalis5509
Everyone told me 4.88 with the 42rle. I have had them in for six months and could tell a difference from my 4.10's. I drive a Rubi also. I just ordered 315 75 16 and going to run 4.88 and see how that does. It recommend 5.13 for that size. Hey the deeper you go the better performance off road.
By brother drove my jeep with the 4.88's and 285 75 16 and said it moved easily. The overdrive in the transmissions can lug the jeep without gearing right causing you to burn more gas.
Go DAWGS
post #9 of 13 Old 11-03-2011, 02:20 AM Thread Starter
ckalogris
thanks for the tips. I have also been told that I should go with 4.56, since 4.88 is to small and may break under pressure... Someone else told me that this is true and 4.88 is more possible to break, but A/T is more "kind" to the gears and transmission than M/T (where 4.88 usually smashes). What do you think? Did you have any problem? Did you have to upgrade anything else, so as to avoid breaking?
post #10 of 13 Old 11-03-2011, 06:19 AM
Wheelin98TJ
JEEP FREAK
4.88 is not weaker, at least not enough to make a difference.
The ring and pinion is not the weak point.
If the ring and pinion fails, its setup error or a faulty gear set.
post #11 of 13 Old 11-03-2011, 09:57 AM
Mortalis5509
Agree above me. Run 4.88.
Go DAWGS
post #12 of 13 Old 11-03-2011, 10:01 AM
AngryTJ
AngryTJ's Avatar
I have this setup with 4.10 gears but not sure the exact RPM at 60mph, Ill check next time Im on the highway.
Check out my build if you want to see pics
AngryTJ is offline
post #13 of 13 Old 11-03-2011, 10:15 PM
Mortalis5509
Your rpm's will be different than his because you have a manual and he has a auto.
Go DAWGS
rpm
