2005 Rubicon rpm's at 65 MPH (Manual Tranny Only) - JeepForum.com
post #1 of 14 Old 05-07-2007, 06:05 PM Thread Starter
cpleasant
cpleasant's Avatar
I was wondering if anyone could post what their Rubicon with the NV3550 tranny (early models) rpm were at 65 mph? I wanted to know because I just had some 4.10's installed in my 02 with the 4.0 and nv3550. My tires are slightly larger than the Rubi (31x10.5 vs. 30.5x9.5)
I just wanted to compare..
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
post #2 of 14 Old 05-07-2007, 06:52 PM
rudy99
http://www.ringpinion.com/Calc_RPM.aspx
Have fun!
2006 TJ Sport Red
6-speed; D30/D44 w/3.73; 33"x12.5 MTRs; Skid Row Engine/Steering Skids; AtoZ Rockers and Rear Bumper/Tire Carrier; Rockcrusher and T&J Diff Covers; 4WheelCustoms 2.25" BB; M.O.R.E 1" MML; PA 1" BL; Mike Green LCA Skids; Uniden Pro510XL w/2' Firestik; Husky Floor Liners
rudy99 is offline
post #3 of 14 Old 05-07-2007, 10:55 PM Thread Starter
cpleasant
cpleasant's Avatar
Let me be a little more specific. looking for 5th gear with people's actual experience.
post #4 of 14 Old 05-07-2007, 11:14 PM
WILLY348
WILLY348's Avatar
My 2006 wrangler unlimited (6 speed transmission 3.73 gears) is at around 2,000-2,200 rpms in 6th gear at 60 mph i believe.. i don't really go to much faster than that. Heck i dont think i've ever gone faster then 65 in my lj
2003 Jeep Wrangler Sport: Current Jeep
2006 Jeep Wrangler Unlimited: (Sold and missed!)
2004 Ford Mustang Cobra
WILLY348 is offline
post #5 of 14 Old 05-08-2007, 06:41 AM
rouxbicon
My bone stock Rubi is spinning 2500 rpm at 70 mph (true 70 as per GPS), which would calculate to about 2320 rpm at 65.
By the way, if you check your tire manufacturer's specs for 31x10.5, you will probably find that the listed diameter is within a tenth of an inch of the Rubi's 245/75R16 OEM tires...essentially the exact same diameters. So your results should be pretty darn close to mine. Remember that your speedometer and odometer will indicate a little different that they did with the stock tires. You might want to GPS verify it. It is not out of the question that it could actually be more accurate with the 31's than it was before.
'03 red Rubi
rouxbicon is offline
post #6 of 14 Old 05-08-2007, 09:10 AM Thread Starter
cpleasant
cpleasant's Avatar
I had to change my speedo gear when the axle gears were changed. It was WAY off. Bad thing is it seems that the website that I bought it from had bad info as to which one I need. I still have to check it with gps to see exactly how far off it is.
post #7 of 14 Old 05-08-2007, 09:29 AM
hoseclamp
hoseclamp's Avatar
65mph x 4.10 ratio x 336 / 30.3" tall x .84 OD ratio = 2,482-2,500rpm.
'04 Rube
JEEPS ARE NOT CARS, STOP CALLING YOUR JEEP A CAR!!!!!!!!
hoseclamp is offline
post #8 of 14 Old 05-08-2007, 02:27 PM
rouxbicon
NV3550 has a 0.78 OD ratio.
'03 red Rubi
post #9 of 14 Old 05-08-2007, 04:06 PM
hoseclamp
hoseclamp's Avatar
The '05's and newer got the 6sp with a .84 reduction, the 5sp like my '04 has the .78, I understood he was wanting the 2005 rpm's, correct? Regardless, the '04 and older style tranny would be pprox 2,[email protected]
'04 Rube
post #10 of 14 Old 05-08-2007, 05:28 PM Thread Starter
cpleasant
cpleasant's Avatar
Sorry, I meant PRE 05 models. My screw up. Its fixed.
post #11 of 14 Old 05-08-2007, 07:01 PM
kingvm
kingvm's Avatar
2005 WK
I checked mine on the way home today and it is running 2350-2400 at 65.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline
post #12 of 14 Old 05-08-2007, 07:41 PM
WILLY348
WILLY348's Avatar
So i guess the 6 speed transmission actually does help a little on the gas saving.. i looked at my tach when i was driving home today and it was like i said.. 2,200 rpms. not to much less.. but its less! (thats 60 mph)
WILLY348 is offline
post #13 of 14 Old 05-09-2007, 06:46 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Lower RPM does not always translate to better gas mileage.
The 6 speed will turn higher RPM than the 5 speeds if all other factors are equal.
Wheelin98TJ is offline
post #14 of 14 Old 05-09-2007, 08:53 AM
Bigbob
Bigbob's Avatar
Correct. From what I am seeing the 4.0 is happier running at about 2800-3000 RPM at 70 MPH or freeway speed. On the ROF there has been a number of people who experimented with running their 6 speeds in 5th gear only on the autobahn and the gas mileage in most cases went up 1-2 and in some case more MPG. Now these were all stock geared Rubicons with the 4.10 axles and 33" tires. The consensus seems to be a 4.88 or 5.13 works well for Jeeps with 33" and 35" tires and standard shift 6 speed transmissions. The 5.13 is best for the 5 speed as it has a higher Overdrive. The 5.13 is the best for automatics. The 2800-3000 RPMs at highway speeds is the sweet spot. Here's a link with a calculator to see what you have.
http://www.grimmjeeper.com/gears.html
I think I will eventually go with 4.88's for my 33" tires.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
Which stock tranny is most trouble free..manual or auto on a 2005 6 cyl wranger X mmmhoss TJ Wrangler Technical Forum 8 11-08-2009 06:29 AM
2005 haynes manual? grandkodiak TJ Wrangler Technical Forum 12 10-06-2009 07:06 PM
JK Unlimited Rubicon 6spd RPM's techmule JK Wrangler Technical Forum 20 05-21-2008 04:35 PM
Service/Maintenance Manual for a 2005 Wrangler Rubicon Sia Bani TJ Wrangler Technical Forum 2 01-17-2008 10:34 AM
Whats the RPM's for Unlimited Rubicon? PatrickBateman JK Wrangler Technical Forum 3 02-09-2007 02:57 PM
