2004 Jeep Wrangler 33" to 37" tires??? - JeepForum.com
 12Likes
post #1 of 18 Old 01-20-2020, 10:13 AM Thread Starter
banksj1250
Trying to run 37's on my stock Wrangler, I have 33's right now. Been looking around for everything that I would need to change, but I know I'm leaving something out???
Anyone who has done this and has a list or something I can start from? I'll do the research, just need to know WHAT to research!!!
So far I'm looking at gear ratio, suspension and body lifts.
2004 Jeer Wrangler Sport
2" lift currently with 33x12.50
THANKS
banksj1250 is offline
post #2 of 18 Old 01-20-2020, 12:53 PM
superjay5ive
I don't think anyone will recommend you run 37's on the stock drivetrain. Not even the rubi Dana 44's are up to the task. Plus you would need to stretch your wheelbase. 35's are max for a stock TJ if you at least have a 44 rear. Brakes, tierod will need to be addressed for 35's at the very least along with gears. If you have a rear 35, you will need to address that. The list can go on and on depending on how you plan to use your jeep
superjay5ive is online now
post #3 of 18 Old 01-20-2020, 05:38 PM
orviston
That is not true. You can do 38” ez on a rubi.
Sent from my iPhone using Tapatalk
orviston is offline
post #4 of 18 Old 01-20-2020, 06:42 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Nothing “ez” about it, unless you are sticking to the mall. Nothing about a stock TJ ruby drivetrain is up to the task if you a planning to wheel it. And the stock brakes would make it dangerous on the street.
TheBoogieman, BM3 and Ironhead like this.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #5 of 18 Old 01-20-2020, 07:54 PM
YellerJK15
YellerJK15's Avatar
I would have to agree with Nashville TJ. I'm in a 2015 Sahara on basically 33.5's and I missed my own driveway by 10 feet the other night haha. Even with the small change from 32.1's to 33.3's (granted they are load rating E, so slightly heavier) brakes are a must. I'm already thinking of upgrading mine because stock jeep brakes, just like the headlights really suck. So I would imagine there's quite a few changes you would discover need to be made, either before or after you make the switch to 37's. (Just my .02 cents)
YellerJK15 is offline
post #6 of 18 Old 01-21-2020, 04:32 AM
TheBoogieman
CORONA-virus survivor
TheBoogieman's Avatar
Can you? Yes. Should you? No. This Rubi with 37s was parked nearby and I checked it out and talked to the owner. Stock (axles, gears, brakes). It didn't even have adjustable control arms. MC flares / 4" lift with Fox shocks and a Big t-case drop too. I wouldn't want to drive it, even on the street.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #7 of 18 Old 01-21-2020, 08:53 AM
tworley
tworley's Avatar
Stick with 35s. Even then you are going to spend some serious money.
Colorado Member 307
tworley is offline
post #8 of 18 Old 01-21-2020, 10:25 AM
TheBoogieman
Can't I just put a 3" BL and 4" SL on my Jeep with my 3.07 gears and run 37s? I had a 2.5L once.
post #9 of 18 Old 01-21-2020, 11:44 AM Thread Starter
banksj1250
Thanks for this! I'm starting to lean towards the 35's now. Saw some other posts that recommended 35's vs the 37's. My truck has 37's right now so I was hoping just to use these and not have to buy 35's. Probably cheaper and better for the Jeep to just do the 35's.
5.13 gear ratio for the 35's the best bet???
post #10 of 18 Old 01-21-2020, 11:58 AM
Ironhead
Ironhead's Avatar
what trans do you have?
Ironhead is offline
post #11 of 18 Old 01-21-2020, 02:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2. That type of information should have been entered into your Profile.
Jerry Bransford is offline
post #12 of 18 Old 01-21-2020, 05:05 PM
tworley
tworley's Avatar
Plenty of reading here on what it takes to run 35s:
https://www.jeepforum.com/forum/f9/i...-my-tj-751873/
Colorado Member 307
tworley is offline
post #13 of 18 Old 01-22-2020, 12:54 PM
Imped
Imped's Avatar
Ugh. I don't miss these kinds of discussions.
TheBoogieman and NashvilleTJ like this.
OlllllllO
IndyORV
Imped is offline
post #14 of 18 Old 01-22-2020, 11:44 PM
sh00ttok1ll
35s are perfect on a TJ.
sh00ttok1ll is offline
post #15 of 18 Old 01-27-2020, 02:00 AM
plumber1
I love the chrome bars hanging down
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
