2003 Rubicon Plastic Radiator Drain plug - JeepForum.com
 1Likes
  • 1 Post By Michael_K
post #1 of 7 Old 06-30-2019, 02:49 AM Thread Starter
motovate
I have a 2003 Rubicon TJ. Pulled the drain plug to drain the Radiator and when I put the plug back in it doesn't tighten up and drains the rad one way I turn it but when I clock it the flow stops but it does have a small drip.
Any thoughts and ideas??? I don't want to change radiators - this one is clean and works just fine - except for the new drip!
LBM
motovate is offline
post #2 of 7 Old 06-30-2019, 05:08 PM
mukluk
mukluk's Avatar
The radiator petcock doesn't normally need to be removed, just opened to the point that it allows the coolant to drain out. You should be able to replace the seal on the petcock if it's leaking, or you can replace the whole petcock (Mopar 4773259/Dorman 490-234.1).
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 7 Old 07-01-2019, 12:51 AM
Michael_K
Michael_K's Avatar
LBM
For this reason, I never open petcock or drain plug from radiator to drain coolant. Years of heat cycle does a lot to things.
I always undo lower hose to drain the coolant.
Michael K.
BrokerDon likes this.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #4 of 7 Old 07-01-2019, 07:52 AM
JEK3
JEK3's Avatar
Michael K.
My petcock got stuck and the wings broke off. Fortunately it was stuck in the closed position and I was able to do exactly this.
JEK3 is offline
post #5 of 7 Old 07-01-2019, 04:02 PM Thread Starter
motovate
Petcock & Lower Rad Hose.
Yea new to me I was surprised it came out. As I understand it now it is basically closed when the handle is horizontal and open when it is vertical. Mine turns all the way around and I finally figured out I didn't have it @ a full 90 and it was seeping out the edge of the petcock. Seems to stop completely when it full 90 degree horizontal. I ordered a new petcock. Any idea on installing it - putting some lube on the O ring to make it slide in easier??
I also see that just unhooking the lower hose drains it much faster and easier. Leave the petcock alone!!!
Thanks
LBM
motovate is offline
post #6 of 7 Old 07-01-2019, 04:40 PM
mukluk
mukluk's Avatar
I'd just use a smear of petrolatum on the new seal before install.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #7 of 7 Old 07-01-2019, 04:49 PM Thread Starter
motovate
Coat the O ring -
Thanks - I have some so I'll slick it up - I also just picked up some spray Dielectric grease - might just spray some of it on. LBM
motovate is offline
