2003 no start/spark - JeepForum.com
post #1 of 6 Old 09-17-2021, 06:04 PM Thread Starter
JeeperYJ95
2003 no start/spark
So I'm helping a friend with their 2003 TJ 4.0
They hit a bump/Pothole about a month ago going about 20mph and the jeep stalled out and died. Another friend looked at it and ended up replacing the computer after a couple of weeks. After replacing it, it fired up and ran around the block and died again. I went over and looked at it this evening. Throwing a couple codes, but appear transmission related.
P0891
P0755
I unbolted the block holding the plug wires on and wedged my ignition tester on one of the boots. When we turned the key, I didn't get any spark.
Looking for opinions on where to start troubleshooting the spark issue.
I don't think there are knock sensors on these. Maybe crankshaft position or camshaft sensor??
Thanks!!
JeeperYJ95 is offline
post #2 of 6 Old 09-18-2021, 05:17 AM
jtec
jtec's Avatar
2014 JK Wrangler
P0891 - trans relay always ON
P0755 - 2/4 solenoid CIRCUIT
jtec is offline
post #3 of 6 Old 09-18-2021, 05:47 AM
jtec
jtec's Avatar
2014 JK Wrangler
Keep you original PCM!!
When you turn key to run/on
Does the CEL come on @ 2 seconds then go out?
>> If yes -
is there 12v to injectors?
Do the injectors pulse as you crank engine?
Is there fuel pressure? post PSI.
Lets try this - as someone tries to start jeep spray some card cleaner or start fluid* into TB - did engine start and try to run on spray - yes or no?
Is thee a POS remote starter or 'kill' switch ?
* second choice, go easy its called boom boom juice for a reason.
jtec is offline
post #4 of 6 Old 09-18-2021, 07:01 AM Thread Starter
JeeperYJ95
I don't think those codes would cause no fire though, right? I didn't check fuel pressure because I wasn't getting sparked so I stopped troubleshooting there....
post #5 of 6 Old 09-18-2021, 07:48 AM
jtec
jtec's Avatar
2014 JK Wrangler
MY THOUGHTS WERE - what a PIA checking the coil output with a coil rail and there are some basics I added - A reason to the madness
The CEL ? Is PCM powering up.
The inj for 12v Is the ASD energizing the systems down stream. easy place to check.
Fuel pressure a BASIC - and will confirm fuel pump esp after hitting big bump.
Those codes being trans issues - That is why I asked if you have the old PCM.
jtec is offline
post #6 of 6 Old 09-18-2021, 09:37 AM Thread Starter
JeeperYJ95
I do still have the original pcm...
