2000 Alternator Direct Bolt on Upgrade - Page 2 - JeepForum.com
post #16 of 30 Old 07-25-2011, 09:00 PM Thread Starter
ColoradoCole
ColoradoCole's Avatar
That little box runs everything electrical on the jeep besides what the stock electrics ran. It runs my two electric fans, heated seats, lights, sub and my radio. You can see it on my thread. And im running fram because i run 5 w 30 but what filter should i be running?
Wiring Cleanup Aux fuse box Step 1
The thread isnt completely updated yet but will be soon.
ColoradoCole is offline
post #17 of 30 Old 07-25-2011, 09:05 PM
wushaw
Rockin jeep
wushaw's Avatar
Anything but Fram, I tried 4 of em in a row and every one leaked, I was just having to prove to myself that they truly are junk.
I run Wix, no issues.
wushaw is offline
post #18 of 30 Old 07-25-2011, 09:06 PM
wushaw
Rockin jeep
wushaw's Avatar
you mean a K&N?
I didn't want to go there yet, only one filter at a time
wushaw is offline
post #19 of 30 Old 07-25-2011, 09:22 PM
micah2074
micah2074's Avatar
i think he's talking about the oil filter.
"I was married once, sir, but she run off with a gypsy. My heart was not ripped out, but she did steal my cuckoo clock."
micah2074 is offline
post #20 of 30 Old 07-25-2011, 09:25 PM
wushaw
Rockin jeep
wushaw's Avatar
Look at the first pic with K&N on the Air inlet tube.
wushaw is offline
post #21 of 30 Old 07-25-2011, 10:23 PM
BYuen
BYuen's Avatar
Originally Posted by Echoman View Post
Is there any reason why you couldn't just cut off that extra mount with a cutting wheel so as not to interfere with the coil pack rail?
You can, but it would void the warranty as you would have modified the case.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #22 of 30 Old 07-25-2011, 10:31 PM
SpeedJeep
SpeedJeep's Avatar
I can not remove the coil pack without moving the alternator. IIRC you can remove the belt and one bolt and swing it up out of the way. Or you can cut off the arm.
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #23 of 30 Old 07-25-2011, 10:39 PM
mogo116
mogo116's Avatar
Anyone kno if this would work on a 98?
mogo116 is offline
post #24 of 30 Old 07-26-2011, 06:14 AM
Echoman
Echoman's Avatar
Gotcha!
Echoman
Echoman is offline
post #25 of 30 Old 07-26-2011, 11:22 AM
micah2074
micah2074's Avatar
yes, i see the k&n air filter and i also see the fram oil filter in that pic.
post #26 of 30 Old 07-26-2011, 11:55 AM
unlimitedlj
I love my Mean Green 200 amp. 117 amps is not enough to run a Jeep with extra's for sure. Leave it to Jeep to do something stupid.
unlimitedlj is offline
post #27 of 30 Old 07-26-2011, 12:22 PM
Necko2529
Necko2529's Avatar
Wonder if you could take Durango alt to a shop and have it rewired for more amps ?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #28 of 30 Old 07-26-2011, 02:21 PM Thread Starter
ColoradoCole
You can always have them rewire.
post #29 of 30 Old 12-13-2011, 10:02 PM
aparke4
aparke4's Avatar
cool thread - going to do this soon for my 01 TJ - alternator has 165 k on it... still works but everything else under the hood is new
aparke4 is offline
post #30 of 30 Old 12-13-2011, 10:07 PM Thread Starter
ColoradoCole
Thanks
160 amp , alternator , durango
2000 TJ Alternator Upgrade 3fifty TJ Wrangler Technical Forum 11 11-08-2016 10:46 AM
Is a Dana 44 out of a 2000 TJ a direct bolt in to my 2004 TJ? grimmster TJ Wrangler Technical Forum 26 04-14-2011 07:50 PM
Direct bolt-on alternator upgrade? tonythehazelnut YJ Wrangler Technical Forum 4 01-04-2010 08:24 PM
Will D44 be a direct bolt on to 87 yj square87 YJ Wrangler Technical Forum 13 04-20-2009 10:50 PM
direct bolt in? ellandoh YJ Wrangler Technical Forum 2 09-28-2005 06:34 PM
