2.5L engine whistle at idle - JeepForum.com
 1Likes
  • 1 Post By mukluk
post #1 of 9 Old 01-13-2008, 06:08 PM Thread Starter
Jeepdawgs
Guest
I have had an engine (2.5L) whistle at idle for awhile now. It will happen when I start it up and when the engine is at idle (clutch in or neutral). It does not get better or worse after the engine is warmed up. It is not present when I press the throttle. I just replaced my idler pulley on my Envoy. When that went out, the engine sounded like a diesel and the noise was present at idle and when I would accelerate. Since the whistle is only present at idle, or when the throttle is not pressed, I am taking an educated guess that it is a vaccum leak. Is my SWAG (scientific wild a** guess)correct and if so what is the best way to test for a vaccum leak?
Jeepdawgs is offline
post #2 of 9 Old 01-13-2008, 06:49 PM
mall0y
What kind of whistling? Is it more like an Intake/TB whistling or a bad alternator/bearing whining?
mall0y is offline
post #3 of 9 Old 01-13-2008, 06:56 PM Thread Starter
Jeepdawgs
Guest
My thinking with bearings is that they would still whine at higher RPM's. Since the sound goes away at higher RPM's I was guessing that I had a vaccum leak somewhere. It sounds like air going through a small opening.
post #4 of 9 Old 01-13-2008, 07:48 PM
JeeperAbe
Guest
I had the same problem..make sure your exhaust and intake manifolds are tight and torqued to spec...i had a leak and it was from a loose bolt.
JeeperAbe is offline
post #5 of 9 Old 01-13-2008, 08:45 PM
carpekd
have you checked the vacuum lines under the hood? I've heard stories of them dry-rotting and crumbling to pieces.
carpekd is offline
post #6 of 9 Old 01-13-2008, 09:12 PM Thread Starter
Jeepdawgs
Guest
I just checked them. They visually look OK. I am debating on just replacing them anyways incase there is a pinhole in one that I can't find. Can't be too expensive, might be the cheapest thing to do first.
post #7 of 9 Old 01-14-2008, 07:57 AM
erickpl
erickpl's Avatar
I'd suspect a cracked manifold. The 97-2000's were notorious for that.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #8 of 9 Old 03-19-2019, 09:31 PM
twhitakerWV
Hi,
Very similar issue for me on a 1995 Rio Grand 2.5L. Whistle at idle but goes away when given gas.
I just visited my local shop and the mechanic sprayed some penetrating oil on the manifold and the whistle stopped when this part was hit. See arrow in photo.
He said would be $500-600 to remove, clean, and fix everything. Any other DIY tips?
Thanks!
twhitakerWV is offline
post #9 of 9 Old 03-20-2019, 12:31 AM
mukluk
mukluk's Avatar
@twhitakerWV
Your arrow is pointing at a casting seam on the intake manifold. If you mean a point just to the left of the arrow tip, the leak is located where the intake manifold meets the cylinder head. Fixing this leak will require removing the intake manifold and replacing the manifold seal. If however you mean a point just to the right of the arrow tip, that is your #3 fuel injector. Fixing this leak is much easier and only requires pulling the fuel rail and injectors out of the intake manifold and replacing the o-ring seals on the injectors (might as well do all four since you can't remove just one).
joeyroe likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
4.0 engine whistle noise? BP88 TJ Wrangler Technical Forum 13 11-17-2011 07:20 AM
Engine whistle? Help 95 YJ 4cyl. zhahn888 YJ Wrangler Technical Forum 5 01-21-2010 01:46 PM
Edge Throttle Body Whistle at Idle? TJShadow TJ Wrangler Technical Forum 17 03-25-2009 05:30 PM
Whistle Noise and Stall At Idle.... Hunta TJ Wrangler Technical Forum 11 12-24-2008 09:38 PM
whistle in the engine winlit TJ Wrangler Technical Forum 2 02-16-2007 08:05 PM
